I just got a new pump installed and was vacuuming my pool today, set to skimmer, and now its not sucking anything through the vacuum. I'm not pool literate really at all. I have searched a fair bit online with no luck. Priming isn't an issue as water is still pulling through there just isn't any suction to pull through the vacuum. Additionally on the normal drain settings it is pumping water fine. My assumption is I have something in the line somewhere; however, with water still coming through on skimmer I'm just not sure. Any suggestions or tips? Hopefully I included enough detail about my inquiry. Greatly appreciate any advice. Thanks
Regards,
Jamie P
Regards,
Jamie P
