Results 1 to 16 of 16
Thread: Going to Test for the First Time
    May 2014
    Central Florida
    66
    I had pool service up until two weeks ago, and they pretty much came once a week and were shocking my pool. I am getting more situated and can start testing my pool on the regular now. This was also the last time my pool was vaccummed and mine is coming in Tuesday.
    My pool has stayed really clear for the two weeks and I have been pouring 10.5% chlorine to keep it clean, and the pump is running for 8 hours each day.
    I am trying to get to go in the pool tomorrow, and I'm hoping the FC levels should be above the minimum safe levels.
    Pool
    16K gallon - Chlorine
    Screen Enclosure (no leaves or any large debris)
    Clear water and easy to see the floor
    Temp - upper 80s
    Weather
    Been raining a lot, but the past few days it's be a bit lighter. I did have to drain the pool at one point due to the rain.
    Kit
    TF-100 XL
    Chemicals on hand
    4 gallons of 10.5% chlorine
    .5 gallons of Muriatic Acid
    What tests do I need to run?
    Do I just pop my results into the Pool Math Calculator?
    Should I go ahead and buy some stabilizer just in case?
    16K gallon in ground plaster pool
    Hayward star clear plus c1202 Cartridge filter
    4 speed Pentair Intelliflo Pump
    TF-100 w/Speed Stir
    Manual Brush and Vacuum
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Going to Test for the First Time
    Hi There,
    You should run all of the test and make sure you perform them according exactly to the instructions included in the test kit.
    Yes, just pop your results into the pool calculator. It is that easy. Dont forget to print, or copy or refer to the recommended levels for your type of pool. SWG or Non, etc.
    http://www.troublefreepool.com/conte...mmended-levels
    Wait until you test for CYA before you go buy any. Having it on vs running to the store will make no difference and may only be sitting there, money spent for no reason of you dont need it.
    Good Luck and let us know how it goes!
    Divin Dave,
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Make sure your pump has been running 40-60 min's prior to taking tests. 😎
    Jeff
    May 2014
    Central Florida
    66
    Did the tests for the first time.
    FC = 12 (24 drops)
    CC = .5 to 1 (1 to 2 drops)
    ph = 7.8 to 8.2 (inbetween two colors)
    TA = 180 (18 drops)
    CH = 200 (8 drops)
    CYA approx 30 (hard to be really precise and not the brightest of conditions)
    Is this pool safe to swim in the tomorrow and do I need to add some muriatic acid?
    TF-100 w/Speed Stir
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Yes the pool is safe to swim in. Your FC is above normal levels for your CYA level. It's at shock level. You can swim in FC levels up to shock level. Just let it drift down. The FC range for a CYA level of 30 is 2-6 and don't let it drop below 2.
    FC/CYA Chart. Use 6 as your target as that will give you wiggle room for FC burn off so you don't fall below your min.
    If your unsure about the PH level use the the color you think is closest. Drop it down to 7.5 just to be on the safe side. Pool Math.
    Take that CC test again tomorrow and see what you come up with. Do the CC test as soon as your FC test goes clear. Don't wait.
    Being in the sunny state of FLA. you may want to raise your CYA level up some to 40-50. How much sun does your pool receive during the day ? 😎
    Jeff
    May 2014
    Central Florida
    66
    Quote Originally Posted by pwrstrk View Post
    The pool is on the north side of the house. It likely starts getting some light sun from about 8 am now until about 6 pm since the light gets blocked when it is on the west side.
    I will do the CC test in the morning. That's a great suggestion on testing the CC and soon as the FC.
    I may run and get some stabilizer tomorrow to help the cya.
    I will add some acid to help lower the pH and help lower TA some.
    There is a bit of a learning curve on doing the tests, but I'm hoping this will be faster in the future. Thanks for the help form this forum.
    TF-100 w/Speed Stir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    No biggie, but for a plaster pool, your CH is a tad low... thats something you can work on in the next few days too
    Divin Dave,
    May 2014
    Central Florida
    66
    Ok, I did the FC and CC test today. After doing this today in the morning, and being more comfortable with the test, my first test probably wasn't perfect. The water continues to look great!
    FC - 14.5
    CC - between 0 and 0.5
    So I added about 20 oz of muriatic acid, and I'm likely to pick up some glass beaker to make the measurement real easy for this.
    Next weekend, I may work on getting my CYA to 40-50. Also, I will double check my CH numbers and address that as well next weekend.
    This week I will continue to monitor FC, CC and pH.
    We had a great time in the pool tonight though! Thanks for all the help on the forum
    TF-100 w/Speed Stir
    Jul 2014
    Chapel Hill, NC
    40
    The pH test can read false high when FC levels are above 10 ppm, so I would recommend waiting to add any more acid or adjust your pH until FC is a little lower. You don't want to overshoot and then have to bring it back up.
    30,000 gal IG pool, vinyl liner, Hayward Superpump 1 HP, Hayward S244S sand filter, Zodiac LM2-24 SWG, Polaris 280 TankTrax cleaner, TF-100 and Taylor K-1776 test kits
    May 2014
    Central Florida
    66
    Ok, I will see what the FC/CC and pH tests are in the morning. In theory I should be below 10 FC by then. We did get some descent rain on Sunday and T-storms are in the forecast for today too.
    The only question I have on the tests for the FC/CC is how clear does the sample have to be for me to declare anything?
    TF-100 w/Speed Stir
    Jul 2014
    Chapel Hill, NC
    40
    There shouldn't be any pink color in the sample. Make sure you're adding drops relatively quickly, about 1 per sec. Immediately add the R-0003 reagent to test for CC, if you let it sit before adding the R-0003 it will turn pink again. Read this post as it has some very good, detailed directions.
    http://www.troublefreepool.com/threa...Kit-Directions
    May 2014
    Central Florida
    66
    Quote Originally Posted by adrob2 View Post
    Thanks for that. I already had it printed it out didn't pay too much attention to the notes.
    All I added was .5 gallons of chlorine this week.
    I tested this morning and my FC was 7.5 and CC was 0. pH was still high even after adding 20 oz during the week. I went ahead and added 30 oz of muriatic acid today, and I will test in the morning again. I'm hoping to at least get something under 8.2 on the test.
    I do have some CYA on hand to get it up to 50 and another 2.5 gallon of chlorine to get my FC higher to go with the higher CYA. I hope to be doing things right. The water still looks very clear.
    TF-100 w/Speed Stir
    Jul 2014
    Chapel Hill, NC
    40
    Sounds like you're on the right track. I would add CYA somewhat slowly, maybe try taking it up from 30-40 initially. Don't forget that if you're adding solid CYA it may take a week for all of it to register on the test and if you add too much the only way to remove any is partial drain/refill. If you're holding chlorine well at 40 then you won't need to take it any higher.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Quote Originally Posted by PoolStudent View Post
    pH 8.2 is the maximum reading on the test, very likely your pH is much higher. You would need to add muriatic acid, let it mix, re-test the water, and add acid again.
    For large pH changes, the recommendation is to add half the recommended amount of acid and re-test.
    Check that you entered the correct TA & strength of muriatic acid.
    Also, how new is the plaster in your pool?
    May 2014
    Central Florida
    66
    The plaster in my pool is old, but I don't know the exact age of my pool.
    I added CYA and about 30 oz this weekend. When I measured today I got 7.8! So I added about 20 oz of muriatic acid into the pool this morning and I will retest the pH tomorrow.
    Also, my CH is about 300, is this ok to leave like this?
    TF-100 w/Speed Stir
    May 2014
    584
    CH is fine.
    You can monitor your pH and see if it holds steady at 7.8, if so there'd be no need to keep adding acid.
