Thread: Mustard Algae?
    rgrountree's Avatar
    Nov 2011
    Atascocita, Texas
    13
    Mustard Algae?
    I have few spots of mustard type algae that are popping up in a few places around the pool. Mostly in the spa and bench areas. These spots brush away quite easily but I am wondering what is causing these to continue popping up. I have not had this issue the last 2 years.
    From Test this morning
    FC = 2 (Target 5, adding bleach daily)
    CC = 0
    pH = 7.6
    TA = 60
    CYA = 40-50
    I have never shocked the pool, as I have never had any combined chlorine or previous algae issues with the pool - Thanks TFP!
    I am wondering if I need to shock or if I need to just adjust my target chlorine level up given my CYA.
    Thanks in advance for your input!
    Rawlins
    23,000 IG plaster pool, Jandy HP Plus 2HP (130 GPM), Jandy CV460 Cartridge filter, Polaris 280, Jandy LXi 400,000 BTU Heater, Jandy Watercolors LED lighting, 7' Raised SPA
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Mustard Algae?
    Increase your target FC.
    FC 2 is below the minimum for your CYA.
    Re: Mustard Algae?
    From experience, Mustard Algae can be a PITA. You can brush it away only to have it reappear a short time later. There is an article on here that discusses how to rid yourself of it. My advice is to raise your chlorine to MA shock level and brush until exhausted and then brush a little more!
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
    rgrountree's Avatar
    Nov 2011
    Atascocita, Texas
    13
    Re: Mustard Algae?
    Thanks for the suggestions.
    I completed an OCLT test overnight and saw only a 0.5 PPM drop in free chlorine. So this is good news I suppose. I will push up my target FC levels based on CYA.
    Re: Mustard Algae?
    Quote Originally Posted by rgrountree View Post
    Don't forget to keep brushing...
    21,100 IG Vinyl
    Hayward Pump
    Sand Filter
    TFPC
    Taylor K-2006 Kit
