Results 1 to 9 of 9
Thread: Cell for CPSC-36 Available
    After having issues with the control board for my CPSC-36 SWG, I decided against paying for repairs. Therefore, I have a three year old cell that was working fine before the control panel quit.
    I hate to have it go to waste so I would be willing to give to anyone that wants it; just pay for shipping.
    PM me if you are interested.
    16K IG vinyl liner - 2.5 HP Hayward Pump - Hayward Sand Filter - CircuPool Si 30 SWG
    Aug 2010
    Dallas, TX
    4,052
    Re: Cell for CPSC-36 Available
    Darn, unfortunately that's too small for mine. A very generous offer for sure.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Hey Robbie, It's pretty much plug and play for your unit, you'd have to go into the maintenance menu to change the cell setting. Are your running your 48 at 100%, If not it might be a good backup.
    Jul 2014
    Peoria, IL
    389
    If I have a cpsc24 is it all the same control panel? My cell is 3 years old an a little undersized.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    Apr 2011
    Murrieta, CA
    2,360
    Yes bdex, they're all the same control panel. You just have to set it up under the maintenance menu.
    Jul 2014
    Peoria, IL
    389
    Ndenunz, where are you located? Kind of tossed up.
    Would this then give me extra "capacity"? I know the 24 is 20k gallons and this one is probably 35k gallons. I have an 18k gallon pool. My 24 has had to be at 100% (which compupool says is same as 50% as far as life expectancy goes??). Could I run a 36 at day 50%. And does it matter? Is that how often it is running?
    Central Illinois
    Aug 2010
    Dallas, TX
    4,052
    I'm running at 90% for 22 hours. I don't think I'd be a good candidate.
    Jul 2014
    Peoria, IL
    389
    My pump runs 24/7 and I was at 100% with my 24 until I started kicking in a little LC to be able to turn down. I need to look into a timer.
    Central Illinois
    bdex:
    I am in NC
