Thread: Latest Readings
    Hoochie's Avatar
    May 2014
    Newmarket, Ontario, Canada
    31
    Cool Latest Readings
    Hi Folks;
    I have been slowly adding borates to my SWG and will continue this weekend. Right now at 10 ppm.
    My latest readings have been pretty consistent. pH is very stable.
    Although today I noticed my CC level (0.5 ppm) I did a search here and figured this is not a biggy right now.
    Can I continue my Borate adventure?
    Pool is sparkling clear and that nasty black stain on my pool stairs has been slowly disappearing (actually rubs off quite easily).
    I run my pump 24/7 (until I can get an electrician to wire my P4 properly). SWG percentage is 10%. I can bump it to 15% but there is no level to set in between and when I do set at 15% my FC jumps higher than the CYA/Chlorine recommend. So I'm in that wierd zone I guess.
    FC is 5.5 > Pool math recommends 1L of bleach. So have added that and should be good.
    Pool temp is a crisp 74F (which is were I like it). Haven't turned the heater on all summer.
    FC 5.5
    CC 0.5
    pH 7.8
    TA 70
    CH 260
    CYA 80
    Salt 3600
    Borate 10
    Thank you all and I am on to my Borate adventure!
    Last edited by Hoochie; 08-09-2014 at 10:02 AM. Reason: Did a search and learned about CC value of 0.5 is good as 0 - doh!
    IG POOL: 100k litres/24k Gal, 2005 Mountain Lake SWG, vinyl,
    EQUIP: Hayward ProLogic P4 + Turbo-Cell-15 + 1HP Hayward Super Pump, Titan TIII 120k BTU Heat Pump, STA-RITE 300lb sand T-240BP-1,
    TEST: Taylor K2006 (FAS-DPD) test kit
    1f u c4n r34d th1s u r3411y n33d t0 570p r34d1ng 51g5 0n f0rum5
    Jan 2013
    Houston, TX
    1,079
    Re: Latest Readings
    I don't see any issues with continuing to add borates. Check out the borate guide in pool school - good reading.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Latest Readings
    No reason to go so slow with borates. Overshooting a little is no big deal. Are you using boric acid or borax and MA?
    FC is ok for your CYA. Min is 4 and don't forget you are safe to swim all the way up to 30.
    Running 24/7 is overkill and wasting electricity. I know you said your timer isn't wired but I assume you could turn it off manually. I would try 12 hour run time at 30%.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
