Thread: Pentair Clean & Clear 150
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    On the bottom of the core there is 1" pipe sticking out, would you say the goes into the female 1" in bottom of the filter, what does it do? Thank you
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Pentair Clean & Clear 150
    Hello,
    There should be a little sock filter on the top of the pipe. It appears to be part of the air bleed.
    Here's the owners manual: http://www.pentairpool.com/pdfs/CleanandClearOM.pdf
    Part 7 Air bleed sock it goes on that pipe.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Yes I have that, but the bottom part, does it go into the opening on the filter bottom? Next time I open it I'll snap a picture. Thanks
    Autopilot SWG
    Apr 2011
    Murrieta, CA
    2,360
    Yes it does. There should be a marking on the top of the filter support that points to the intake. The pipe is on the opposite side. Its a snug fit sliding it in.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    OK, I put it in there, it wasn't before, it seems like my pressure dropped from 10 to 8 when I did that. Thank you works great.
    Autopilot SWG
