Need help with Intermatic p1353 settings.
bbq
0
Aug 8, 2014
6
Texas
Brand new (overwhelmed) pool owner here.
I have a Hayward Super II pump, Pentair CCP filter, Intermatic p1353 (I think), ~20,000 gallon plaster pool.
The previous owner had it set to mode 3
I 'm not sure if anything is plugged into circuit 2... the heater maybe?
Circuit 3 I think says cleaner (says booster on the cover plate). But, I don't see a second pump anywhere...
What would be a good starting point to program into the timer? Also, is there a way to clear a single event? I only see in the manual how to clear all events at the same time.
Mode 3 is to make sure when you start circuit 3 for my cleaner boost pump it automatically starts the main pump on circuit 1 if it already hasn't been running. I use circuit 2 for my swg. I just set it to the same run time as my filter pump. I set my circuit three to run at different times (9am to noon) than the main pump which runs from 7am to 7pm now. Yours may not have anything connected to Circuit 2.
