Thread: Would sawing off 1 1/4" taper improve circulation?
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    It seems every connector I have (hose fittings, vacuum head, etc) has a smaller diameter at the beginning. Does anyone remove that part of the adapter to improve flow rate?
    * 18' x 33' - 48" oval AGP - new liner Summer 2014
    * Hayward Pro Series S210T Top Mount Sand Filter
    * Hayward Power-Flo Matrix 1 1/2 hp Pump Model SP5615
    (equipment on posts prior to summer 2014) Hayward PowerFlo 1 hp pump - Jacuzzi "Tidewater" 190L, sand filter
    Onslow's Avatar
    Jul 2010
    Kentucky
    140
    Re: Would sawing off 1 1/4" taper improve circulation?
    Perhaps I should add or restate - do they sell fittings/connectors that stat at 1 1/2"? The barbed pump to filter connectors do not seem to be appropriate when I tried to connect to a hose other than the thick rubber line those are made for.
