Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: time to replace?
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    time to replace?
    I probably already know the answer here but just want to verify before I go spend more money... My SWG is still the original one the PB installed in 2008. Haven't had a problem with it EVER. I have never used anything but BBB. All of a sudden it is saying there is no power (that light isn't lit) but it shows my readings. I have unplugged it and plugged it back in...no change. The flow light isn't lit either. It seems to be reading my salt fine...showing the increase as I have added some, but it doesn't appear to be generating chlorine...keep having issues keeping it up. So, 6 years is about as long as I can expect it to last, right? Time to bite the bullet and replace it??
    Karen
    10,700 gal IG vinyl
    Pentair Triton II TR50 sand filter
    Hayward SharkVac XL cleaner; Emerson 1HP pump
    Bioguard Mineral Springs SWG
    2 skimmers
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: time to replace?
    Can't find a manual for your exact model but this one's troubleshooting guide might give you some ideas : http://www.parpools.com/Page/Help/Te...pring-MS10.pdf
    Solar Blanket, Well Water, Borax Added. 68
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Well, there's a novel idea! I have the manual! Don't know why I didn't think to look there first! But, in looking there, I think it has pretty much told me what I didn't want to hear...my cell has died! I changed the fuse even though it didn't look blown and still no lights. When I run through the numbers, the cell voltage and cell current both say "0" when it should be reading something since I have it set to 100%. Grrr.... Thanks for your help!
    10,700 gal IG vinyl
    2 skimmers
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Hey.............you had a good 6 year run if worse comes to worse! Is the electrode clean where the power goes to it and no calcium buildup on the business end?
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Yeah, I did. It's only in the last couple of weeks that I've seen issues though. I had to keep it turned down because it would produce TOO much chlorine! Everything is clean as a whistle so guess it's just at the end of it's life...sniff...sniff! So, I'm looking at the ones online and want to make sure I'm getting the correct one. My cell says T-15 on it. When I look this up, I see a Hayward that's for Aquarite, Hayward, etc. that says it's for a 40K size pool. When I choose the one for a 15K pool, it says I will be ordering the cell T-3. Is that right? Have I just had to bigger capacity one instead of the right size one? Don't want to hit "place order" until I'm sure! Thanks for your help!
    10,700 gal IG vinyl
    2 skimmers
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Well....I came across a site nocellpower.com...anyone heard of this one? It kinda described what I had going on...no readings or lights for the cell. It tells of a Hayward issue that a lot of people have had in that their system is telling them no cell power and all it takes is a small fix but that either Hayward doesn't know about it or doesn't want anyone else to know how easy a fix it is. So, before I hit that "place order" button, I decided to investigate. I pulled the front off the motherboard of the salt system and found this piece had corroded to the point that it broke off in my hand...
    Here's where it was connected...
    Anyone know what this is and if this is replaceable...or am I looking at a new motherboard?
    Thanks!!!
    10,700 gal IG vinyl
    2 skimmers
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Pretty sure that is a varistor (voltage dependant resistor) which may be used for inrush current limiting. If you can read the codes off it you should be able to replace it (eBay or digikey would be my first stops).
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    That's a known problem. Replace and you should be good to go. Check you tube they have videos on replacement.
    nedchavez's Avatar
    Jun 2012
    Grand Rapids, Michigan
    111
    Svenpup is right. Looks like an MOV - Metal Oxide Varistor
    16' x 32' IG vinyl liner w/ hopper bottom (12,500 gal), Single-speed 1 HP Sta-Rite pump, and 300# Cristal-Flo sand filter, TF-100 test kit
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Thanks for the info! I think you're right... I'm a little overwhelmed with all that is out there on these! I may not be searching correctly, but I'm not finding any info that pertains to this in a SWG. I see plenty on MOVs and what they do but nothing that points me in the direction of which one I should get and then how to go about putting it in. I'm assuming I should be getting a 220v since that is how the electrician set my system up....at least with the capability of 220. I think everything is running on 110 with 220 available. Can someone steer me in the right direction so I get the correct thing?
    Thank you!
    10,700 gal IG vinyl
    2 skimmers
    nedchavez's Avatar
    Jun 2012
    111
    time to replace?
    Sorry, its actually an inrush current limiter. You can get the part at Digikey (part# 570-1062-ND):
    http://www.digikey.com/product-detai...1062-ND/363379
    The site you posted earlier has a video on how to solder. If you're not comfortable soldering, buy the part and take it to a repair shop and have them do it for you.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Awesome! Thanks nedchavez! I have ordered that part!
    10,700 gal IG vinyl
    2 skimmers
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Let us know how it goes.
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Will do! I leave next Sat for vacation so I probably won't deal with it until I get back. Unless of course by some miracle I am actually ahead of schedule in my getting ready to leave....yeah, nah...that'll be week after next before I deal with it! I appreciate all your help! The part was $2.30 so if this doesn't work...who cares!
    10,700 gal IG vinyl
    2 skimmers
    May 2009
    St. Louis, MO
    45
    I had the same problem. No power light, but the numeric reading was working. I replaced the part cited above - $2.49 at Digikey. It worked! The system came on and worked for about 10 days. Now, the power light is off again. Maybe it is the inrush part again, but doesn't that seem odd -- it lasted only 10 days? Any other suggestions of what I should look for? I've replaced the whole board twice in 8 years, since I didn't know about this fix earlier. If there is another problem, why did this fix work for 10 days?
    30,000 galllon, inground, vinyl liner, L-shaped pool
    1.5 hp pump, sand filter, heater, run pump 24/7
    Aquarite salt system
    St. Louis, MO, USA
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Okay...I'm back and have been looking at the videos on how to do this....seems simple enough. I do have a question though...the "leads" (I don't know what they are called! The 2 wires that come out of this thing..) are obviously longer than is needed. I can just cut them to length, right? That won't mess anything up will it?
    10,700 gal IG vinyl
    2 skimmers
    Jul 2014
    Bastrop, Louisiana
    199
    No it wont mess anything up.
    Just remove the old leads off the circuit board and install the current limiter with the bottom of it about 1/8" off the circuit board. After soldering the new limiter in place, just cut off the excess length of the leads so it looks like the other parts on the board.
    If you have problems with this, come back here and let us know, someone can walk you through this easily enough.
    Randy H.
    Intex 18' X 48"
    G.A.M.E. Sandpro 75 Sand Filter (Single Speed 3/4 HP, 75 lbs sand, 2650 GPH, 7-way valve)
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Okay, went to Radio Shack, bought their kit, soldered the piece onto the board.....
    Here's the front....
    And here's the back....
    My questions now are... 1) do I need to let this dry before I put it all together? It's probably dry before I finish this post so that may be a moot point! AND 2) are the scratches on the back a problem? The solder pen got away from me a little bit and it scratched the surface. I noticed that there are lines there and from one of the videos I watched (although on a TV panel and not a SWG panel but I'm assuming the same logic...), the guy said not to "hurt" those...
    Well, I'm off to see if my handy-work did the trick!
    10,700 gal IG vinyl
    2 skimmers
    midtngal's Avatar
    Oct 2007
    Nashville, TN
    485
    Well, unfortunately that either wasn't the problem or I messed it up with the scratches. It still is showing no power but does show a water temperature and a salt reading. Is it safe to assume I just need a new motherboard?
    10,700 gal IG vinyl
    2 skimmers
  20. Back To Top    #20
    Jul 2014
    Bastrop, Louisiana
    199
    Sorry to hear that this was a fail. I have to congratulate you on a fairly good solder job, my first time looked like a train wreck in college.
    Take a good hard look at the "lines". Those lines are actually copper plate that the electricity flows through to the different components on the board. Think of those lines as a wire. If you scratched one of those lines through the copper plate, the wire got broken.
    Well Google your SWG and see what a replacement board will cost vs a new system. I have a feeling that the board is going to be quite costly so you might be better off just replacing the whole unit.
    Again, sorry for the fail....
    Randy H.
    Intex 18' X 48"
