Thread: Booster Pump Now a Geyser - First Q: What is it?
    happyheathen's Avatar
    Sacramento CA
    225
    Ok, got a spiffy pressure-side cleaner - and it works quite well - if you ignore the water level constantly dropping, and the power switches at the pad are about 8" from getting sprayed.
    Some on has removed a riveted-on plate, and "Goof off" made a blurry mess of the remaining plate.
    That leaves pics:
    That are 4 pass-through bolts holding the pump to the motor they take 9/16 on bolt and nut (FWIW)[IMG][/IMG]6 wrench on both head and nut, FWIW.[IMG][/IMG]
    It is 12.5 from face of inlet port to back of motor and approx 6.5 " dia.
    The rest of the orig equip (which this looks to be (mid-80's)) was Sta-Rite.
    I'm hoping that and the blue paint are enough to id.
    I'm in the middle of a SLAM, and this is notplace to have to shut down pumps (even with the booster off, the spray from it is impressive).
    Dave
    Sacramento
    1980's 15,000 Gal IG Plaster; 1 1/2 hp Hayward Northstar; Hayward Swimclear C3025 Cartridge Filter (325 sq ft, nom.); Pentair Legend; Polaris PB4-60; Equipment 40' from pool. p.s.: it's an aye-aye.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Re: Booster Pump Now a Geyser - First Q: What is it?
    Tried to find it but no luck, sorry.
    Solar Blanket, Well Water, Borax Added. 68
    Sacramento CA
    225
    Thanks!
    There's always JB Weld...
    Dave
    Sacramento
    Sacramento CA
    225
    C'mon - sonebody's got to be old enough to remember this (mid-80's) freak!
    And, I'm afraid the plate webbed plate at the front is cracked....
    Dave
    Sacramento
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Quote Originally Posted by happyheathen View Post
    There isn't any doubt that plate is cracked. I can see it from Wisconsin
    Sacramento CA
    225
    Duh... I was so concentrating on the horizontal spray from the (upper left) bolt, that I didn't even notice the rest of the mess.
    Those cracks certainly explain why that bolt torqued down so easily...
    Thanks!
    Dave
    Sacramento
