Results 1 to 7 of 7
Thread: Aeration to lower pool temp?
    First Pool Judith's Avatar
    Feb 2014
    Georgetown, Texas
    57
    I'm not even sure if this is worth it, but I've been contemplating leaving our 12" sheer and bubbler on to keep the water moving - hoping that the pool water will not get as warm. Is this even a good idea or will it even make any noticeable degree of difference?
    We're in Austin and average temps have been hitting over 100 degrees. Pool water is 92 degrees.
    My concern is how much Muriatic acid I will have to add daily. I'm not worried so much about the cost - just is it a good thing to do...?
    FC - 4.2
    CC - 0
    PH - 7.6 - I add muriatic acid every time it climbs over 7.8 which seems to be every 2-3 days. I drop it to 7.2 but it climbs pretty quickly. Pool is 9 months old.
    CH - 340
    CYA - 45
    Thanks in advance for the advice!
    Judith and Brian D
    16,000 gal; IG Quartscape; Cartridge Jandy CV460 (150 gpm Max); Jandy Pro 2.0 Variable
    Polaris PB460 3/4 booster; Polaris 280 Cleaner; In Line Chlorinator Tri-Chlor (don't use it) Ozonator
    Fill Date 11/11/2013
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Re: Aeration to lower pool temp?
    Guarantee you I'd do what I needed to do to drop that pool temp in Texas. Won't hurt a thing to add more acid than normal to be able to enjoy cooler temps. Gonna run my aerator tonite! (and buy more MA in the morning).
    30,427
    Your idea is very solid but I am not sure you are delivering enough water into the atmosphere to get the drop you need/want.
    The higher you can sling the water and the tinier the drops, the more effect evaporation will have on the pool.
    Fountains are most always the most effective and you can search and find several examples on the forum. I am just not very confidant you will get the effect you want from the bubbler.
    For some reason, my increase in muriatic acid cost seems remarkably small. I have never tried to figure it out but rather just been thankful it has been so economical.
    Jun 2013
    East TN
    309
    I have a shower head that adjusts anywhere from a stream to a mist. I can turn the water on hot as it goes and put it on mist and by the time it hits me, its cold because the air is cooler than the water. The next size up is like a regular spray and is still hot when it hits me. Just an example from what duraleigh said.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    Jan 2013
    Houston, TX
    1,079
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Feb 2014
    Georgetown, Texas
    57
    For some reason I am having issues on the forum looking at pics but I read the post thread. I did some research and found this. I'll chat with them tomorrow to find out where it installs and am definitely going to order this
    http://www.mistcooling.com/pool-cooler.html
    Judith and Brian D
    Curious. What's your TA. Adding acid every 3 days and having it climb from 7.2 to 7.8 seems like a lot of variability unless you have a ton of water features.
    15 K gal/gunnite, 600 gal attached SPA, Hayward: ProLogic, ColorLogic LED, Super II pumps, 400k BTU heater, StarClear cartridge filter for, SwimClear cartridge filter . Pentaire: booster
    http://www.troublefreepool.com/detai...l?hilit=corpus
