Results 1 to 10 of 10
Thread: Can you change the color of the linked text?
    gonefishin's Avatar
    Joliet, Il.
    413
    The color of the linked text shows up as a color very similar to the regular font color. This makes it difficult to recognize when some may have inserted a link in the message.
    thanks,
    dan
    33' Aqua-Leader AGP
    Hayward cartridge filter and IntelliFlo VS pump.
    Solar Heat coming ; used to own Aqua-Cal HeatWave 100k (HeatPump)
    Aqua-Rite t-15 SWG
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    No, you can't, but you can underline the text. Here is an underlined link to TFP.
    Just use the tags before and after the text you want to underline within the link.
    EDIT: You can, in fact, chagne the color.
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Actually we can change the color using [color=red] or something similar. But it would be way better if the admin changed the default appearance of all links globally. As it is it is very difficult to tell what is a link and what isn't. Even though people can highlight links in their own posts using the special codes, most people won't remember, or know how, to do that. As it stands it can be rather annoying. I had one today where I was looking for a link to chemgeeks pool equations and couldn't find it even though I was looking right at the sentence that contained it. I ended up reading the HTML source for the page to extract the link.
    SeanB's Avatar
    Mar 2007
    2,622
    Jason, you're right. I was going about it the wrong way. You can use the color tag as long as the code is directly around the text portion and not the url part of the tag.
    However, I will check into changing it so that the link is a different color. Personally, I prefer having them underlined.
    TFP Founder
    gonefishin's Avatar
    Joliet, Il.
    413
    Quote Originally Posted by SeanB
    I believe you may be able to do both the underlined and color change on your end.
    Thanks for looking into this
    dan
    33' Aqua-Leader AGP
    Aqua-Rite t-15 SWG
    East Tennessee
    278
    How is this
    Google
    Steve
    Echo Canyon II by Artesian Pools, 13.5 KGal AG Round, 22" Artesian Sand Filter 2 hp Artesian pump
    Med Lab Tech for 12 years in E.TN
    Chem testing by Trouble Free Test Kits
    SeanB's Avatar
    Mar 2007
    2,622
    That works!
    Thanks.
    TFP Founder
    Much better! Thanks!
    MedVampire
    You rock!!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    gonefishin's Avatar
    Joliet, Il.
    413
    Thanks a bunch guys!
    dan
    33' Aqua-Leader AGP
    Aqua-Rite t-15 SWG
