Results 1 to 8 of 8
Thread: Adding CYA to pool
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    Adding CYA to pool
    I just bought a 25 lb tub and I know your suppose to put it in a sock in front of the return or in the skimmer. My question how do you know how much 80oz is? And can you handle the acid or do you need gloves? Any other tips would be appreciated.
    30K gallon 20 X 40 IG vinyl built 8/2013, Hayward 1.0 hp super pump, 250,000 BTU Hayward heater, S244s Hayward Sand Filter w/side mount multi port valve, Hayward Aqua Rite Salt Chlorinator with Turbocell T-15 , Coverstar automatic pool cover with key switch, TF-100 test kit.
    Oct 2013
    Chapin, SC
    1,141
    Re: Adding CYA to pool
    I have a small electronic digital scale to weigh mine. Works great! Just carefully pour the stabilizer into a sock so as to not breath too much of the dust from it. I use my bare hands to squeeze the sock to help dissolve it quicker. Acid is a bit trickier. I would carefully pour it into a large measuring cup and trickle pour it into a return stream.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    A kitchen or postal scale is the easiest way to measure.
    CYA is acidic but not overly strong. Just wear cleaning gloves (it's an easy enough precaution to take )
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    If you don't have a scale, pool math also gives measurement by volume (8 oz volume = 1 cup).
    80oz by weight would be about 10.5 cups CYA.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    Thanks for the help, I just seen the volume on the calculator.
    Aug 2010
    Dallas, TX
    4,052
    I've never used gloves for handling CYA. I'm still here and still have all my fingers.
    calespool's Avatar
    Dec 2013
    Savage, Minnesota
    21
    LOL I just used a 16 oz cup and poured about 20 oz into two socks and put one in each skimmer. Will test in a week and add more if needed, don't want to overshoot.
    Aug 2010
    Dallas, TX
    4,052
    Good plan!
