Thread: Hayward SP1480 Installation Question.
    Aug 2013
    North Babylon NY
    21
    With regards to the Hayward SP1480 Union, does it matter which part/end should be connected to the filter and which to the pump?
    One part of the union looks to be the "receiving" (cup-like) end with an o-ring, and the other part looks like a "ball" fitting. If I were to guess, I would say the receiving end would be connected to the filter, as the water flow is coming from the pump?
    Also, should the o-ring be lubed?
    Thanks in advance for any help....
    15'x30'x52" AG Oval Morada II. Hayward PowerFlo Matrix 1HP. Hayward EC40 DE Filter
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hayward SP1480 Installation Question.
    Union can go in either direction. Usually lubrication of the o-ring is not needed but a very small amount of a teflon based grease doesn't hurt. Magic Lube is good stuff.
    Isolated Spa - 345 Gallons
    Aug 2013
    North Babylon NY
    21
    Thanks for the info!
    For this type size plastic/pvc fitting, would channel-lock pliers be the best tool to use for additional tightening? I ask this because I've used the channel locks in the past, and I chewed up the sides of the fitting from the plier's teeth. So instead, I was thinking of maybe purchasing a large adjustable wrench? Would this be better to use?
    Just curious as to what other folks use for this purpose....
    38,369
    Try a strap wrench ... or in a pinch you can actually use a belt.
    Feb 2014
    Central Minnesota
    5,080
    Hand tight should be sufficient. If you really feel that's not enough, a rubber strap type wrench works well.
