Results 1 to 14 of 14
Thread: So far so good!
    Jul 2014
    Hudson Ohio
    142
    So far so good!
    Pools been up and running for a few weeks now with no real issues. I decided I had better check the chlorine in the cartridge and notice it was just about gone. Used my test kit and saw I was at 2ppm FC 0 CC. Ran to the pool store for another cartridge of Trichlor (just finishing out the season). My CYA is still maintaining at 20ppm but I did use pool math to calculate a 8.25% bleach add to get my FC to 4ppm before adding the cartridge. It seems to do the job at maintaining the levels but the price is stupid. Like $28 for 2 cartridges that will get me about 4-5 weeks.
    24'x54" AGP 13,500g AquaLeader Sentinelle | Hayward Voyager CC150 sqft cartridge filter | Hayward 2hp 2spd pump | Hayward Aquaray Cleaner
    Oct 2013
    Chapin, SC
    1,141
    Re: So far so good!
    Cartridge of trichlor? I might be wrong, but the only way I've seen them is pucks or bags- and I've not seen bags except for dichlor. Stick with the bleach or other liquid chlorine so you don't end up with a cya problem.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: So far so good!
    Sounds like a great plan, Mr. Ramsey. You're farther north than I and at most we have only a few more weeks of the season (unless you have some great heat source). With a current CYA of 20, you should be good with pucks. Great job on adding the liquid chlorine quickly! As you know, keep it above minimums to avoid problems.
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Jul 2014
    Hudson Ohio
    142
    Re: So far so good!
    Quote Originally Posted by timerguy View Post
    Trichlor-
    Quote Originally Posted by northrn View Post
    A great heat source lol. Been swimming in a balmy 72 degree water. Not so bad when the sun is out though. I have kicked around the idea of a heater but figure I will let it go one more full season before I make the determination to add one or not.
    jccams's Avatar
    Dexter, MI
    95
    Re: So far so good!
    Think of a plastic housing full of small pucks, like 3/4" dia x 1/4" thick. I had one in my pool, I believe it was swimway?
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    Jul 2014
    Hudson Ohio
    142
    Re: So far so good!
    Quote Originally Posted by jccams View Post
    Yep that sounds a lot like it. At any rate if my CYA was higher I would have used just the bleach but being that there are only 4-ish weeks left to our season and I decide to turn the chlorinator to its highest setting for some reason CYA will not be an issue.
    Oct 2013
    Chapin, SC
    1,141
    Re: So far so good!
    Are those small pucks the only thing you can put in the place you put the cartdige in? Or can you put in say 3" pucks? Further, what weight are the pucks inside each cartridge?
    Jul 2014
    Hudson Ohio
    142
    Re: So far so good!
    The only advantage that I see to the cartridge is that I can adjust the flow rate through the cartridge so that there is some control of the amount that is released. If I had a source for the 1" tablets I could refill the cartridges. The downside to using bleach is the waste (meaning the plastic jugs). I keep it on the lowest setting running my pump on low speed at 3 intervals of 4 hours per day. At least so far this has kept the parameters in check. My pool is kept covered when not in use for the most part.
    Oct 2013
    Chapin, SC
    1,141
    Re: So far so good!
    That's not really an answer to my questions. I'm trying to figure out if there is a less expensive way of using pucks. Or, how much those tiny pucks you're using weigh to see how much cya you're adding by using them.
    Jul 2014
    Hudson Ohio
    142
    Re: So far so good!
    According to the package it is 1.5 lbs.
    Oct 2013
    Chapin, SC
    1,141
    Re: So far so good!
    I'm not sure the package would have anything on the label but net weight (since I don't have any experience with that kind of trichlor). Do you have some way to weigh the pucks themselves?
    jccams's Avatar
    Dexter, MI
    95
    Re: So far so good!
    If this chlorinator is anything like mine you would have to cut the plastic cartridge open in order to remove a puck.
    Jul 2014
    Hudson Ohio
    142
    Re: So far so good!
    I didnt weigh the puck but the empty cartridge was about 3 oz leaving 21oz of pucks so maybe the equivalent of 3 - 3" pucks??
    Also my cartridges just have a plastic plug that is removable. Wonder if I could just refil with 1" trichlor???
    Oct 2013
    Chapin, SC
    1,141
    Re: So far so good!
    I've weighed my 3" pucks some are 7oz per and other 8. So, I'd guess that could be close. Now to do the math and find out what the cost diff would be. I'd say to put the cartridges away and use them for when you're going on vacation and use Liquid chlorine for day-to-day chlorination. Yes, you will end up putting the jugs in a trash collection Like I did for about a year till I installed my SWG this spring. I'll never go back to liquid except in an emergency! And certainly absolutely never back to solid!!!
