Results 1 to 8 of 8
Thread: Backyard Basketball Court
    Jul 2008
    Sinking Spring, PA
    58
    I am planning on building a pool next spring. As part of the project I want to put a basketball court in my back yard. The size will be approximately 25X30. Due to township zoning requirements I cannot use anymore concrete or asphalt since I will have used up my allowance of non-porous material around the pool. If I use anymore I need a "water management plan".
    I found outdoor court compnaies on the net, but thay all need concrete bases.
    Any ideas?
    Thanks!
    4th Year Pool owner in Sinking Spring PA
    46'x23' Free Form Concrete (34,000 gallons), Aqua Blue Pebble Sheen Finish, Pentair IntelliChlor SWG
    Pentair Intelliflo Variable Speed Pump, Pentair D.E. FNS Filter, Pentair MasterTemp heater.
    Richardson, TX
    287
    Re: Backyard Basketball Court
    I ran across these guys: http://www.dallasbasketballcourts.com/b ... courts.htm While doing some research on garage floors, I'm not sure if it's a concrete base or not but they say something about some kind of injection molding...sounds interesting...love to get one of their batting cages if I had the room to live out my youth dreams
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by primetime
    The pool doesn't count?
    Jul 2008
    South Eastern PA
    40
    I've seen porous concrete before at a trade show ... something like this.
    Would this work and keep the township happy as well?
    8200 Gal Vinyl 18' AG Vogue Pool
    150lb Hayward Sand filter with 1-1/2 HP Maxim Pump
    Intex SWG
    Some of the most helpful links for pool owners: Pool School | Pool Calculator | The best test kit | Chlorine/CYA chart
    Jul 2008
    Sinking Spring, PA
    58
    Quote Originally Posted by jugger2500
    Very interesting! Thanks for the link.
    I am going to set up a time to meet with the township in the next two weeks. I will present this as an alternative.
    Jul 2008
    Sinking Spring, PA
    58
    Quote Originally Posted by uwimage
    I sent versacourt an email to see if there is a dealer near me.
    Thanks!
    Riles_J's Avatar
    Nashville, TN
    218
    That pourous concrete is called Concrete Treated Permeable Base and is stiff and allows plenty of water through the pours. I had never thought about using it for a basketball court but that sounds ingenious. There is also an equivalent asphalt product. As you might guess it is call an Asphalt Treated Permeable Base and is actually even more poursous than the concrete version. Both of these products are used to get water out from underneath a concrete surface course in a hurry to try to prevent damage.
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Jul 2008
    South Eastern PA
    40
    I hadn't realized when I first responded to your post that you were in the Reading Area. I live in Bernville, and work in Sinking Spring. Nice to see someone from the area.
    It will be interesting to see what the township says, some of the townships in the area don't exactly seem to be open minded.
    Intex SWG
