Thread: Cleaner for spa/waterfall spillover basin
    Sep 2013
    Knoxville, TN
    2
    Hi everyone. I have been reading and learning for about a year (new pool owner)--this is my first post. We have 2 areas that I'm struggling to keep clean, the spa and spillover basin. Does anyone use a separate cleaner for these areas? Our kreepy krauly does a great job on the main pool, but these two areas always have major dirt/dust/sand that I can't seem to get rid of. Any help/recommendations would be appreciated!
    38,000 gallon, IG freeform gunite/pebble, SWG
    Hayward Cartridge filter, 2 Hayward TriStar VSP, spillover spa, infinity edge with basin
    kreepy krauly cleaner
    schurtj's Avatar
    Jan 2014
    Reynoldsburg, Ohio
    20
    Re: Cleaner for spa/waterfall spillover basin
    Welcome to TFP!
    Depending on the size of the area, you might try the Polaris Pool/Spa wand. It is an inexpensive manual vac that sucks up water into a fine mesh filter basket.
    When I say manual, I do mean manual! Everytime you want it to suck in some debris, you have to manually pull back the plunger. It is work, but this thing is surprisingly effective. The only thing it is missing is a brush to scrub with, but that might be available in the form of an attachment.
    22,750 gallon in-ground Vinyl Liner (1 main, 2 skimmers, 5 returns) 16x38 from 4' to 9'
    1hp A.O. Smith coupled to Hayward Superpump 52gpm
    300 lb Sta-Rite Crystal-Flo sand filter
    Hayward Comfortzone gas heater
    Manual Pool Vacuum (yes seriously)
    Sep 2013
    Knoxville, TN
    2
    Thanks! I will check that out! On a different note, I'm from Westerville originally---love central Ohio!
    schurtj's Avatar
    Jan 2014
    Reynoldsburg, Ohio
    20
    Small world! I was sitting in Westerville when I responded to your post!
    I throw the manual vacuum in from time to time. I've got the Polaris wand as well but
    It's more work.
    14,000 gallon IG plaster pool, Cartridge Filter
