Thread: Zippy cleaner by Barracuda
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    We recently replaced our pool steps with the wedding cake style stairs. The pol cleaner we use is the Zippy by Barracuda and it keeps getting stuck under the stairs because they are raised off the floor a little bit.
    My question is does anybody know of any attachments for these step we could put on so it doesnt keep getting stuck ?
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Re: Zippy cleaner by Barracuda
    I don't have any solutions as to your cleaner getting stuck.
    What I wanted to know is how do you like the cleaner besides that issue, I saw the windows media video of one in action from the Zodiac website and it looks like it does well.
    Intex 15' X 48" metal frame pool
    Waterway Supreme 1hp 2 Speed pump
    Hayward X-Stream 150 Sq. Ft. Cartridge Filter
    2-2'x20' Sungrabber Solar Panels hooked up in parallel on a Goldline GL-235 controller.
    Not getting "Pool Stored" = Priceless!!!
    Thank you TFP
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    It works great ! We had the reg style of stairs and the zippy never got stuck. We just recently switched to the wedding cake type that sit up off the bottom just enough that it gets stuck. But I love it! We used to have a Polaris and it was JUNK !
    Les
    Helpful Links:
    Crzyfrlss1's Avatar
    Jun 2008
    Central, CT
    161
    Thats great I've been considering getting one.
    Now for your stair issue, now that I've thought about it a bit.
    Maybe you could find a way to lower them a little bit so the cleaner doesn't get stuck?
    Thank you TFP
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    The problem is there are feet on the bottom of the steps with suction cups on them so there is no way to lower it ...
    Les
    Helpful Links:
    JoshU's Avatar
    New Orleans, LA
    543
    Hayward makes blue tubes that go under ladders so that cleaners don't get stuck. It was made to work with their above ground suction units. I'm just wondering since the Zippy is a wheeled-unit if this would work or not.
    Hayward Part # AXW100
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
