Thread: High Alkalinity / Low ph
    Aug 2014
    Las Vegas, NV
    2
    I've been fighting this battle for 10 years, and no one has given me workable solution. My pool is 9000 gallons, fiberglass/ceramic, and is covered during the winter. Water is extremely hard and very high ph (Las Vegas). I use triclor. Within several weeks of opening the pool, the ph drops dramatically. I continually add ph increase on a weekly basis, which, in turn, dramatically raises total alkalinity and scaling begins. Some have suggested adding muriatic acid to drop the alkalinity, which, in turn, drops the ph. Others have suggested not worrying about the alkalinity. I usually just end up dealing with having to raise the ph, live with the higher alkalinity, brush away the scale, and change out half the water each spring. Any advice?
    38,354
    Re: High Alkalinity / Low ph
    Welcome to TFP!!!
    Your pH is dropping because you are use the trichlor tablets.
    What is in "ph increase"? If you use borax to raise the pH, the TA will not rise as much.
    You do realize that the tablets are raising your CYA level as well and ultimately that too will required replacing water, right?
    I suggest starting to read some of Pool School starting with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Aug 2010
    Dallas, TX
    4,052
    You don't need to use pH Increase. Just aerate the water somehow - fountain, turn returns upward, etc. That way TA will lower, and in turn eventually will stabilize pH.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by RobbieH View Post
    His pH won't stabilize if he continues to use Trichlor tabs since they are acidic. He needs to 1) get a proper test kit, 2) post a full set of test results, 3) take corrective action based on those test results. I suspect the CYA is high so that a partial drain/refill may be needed, but we should get accurate test results first before recommending anything.
    Aug 2014
    Las Vegas, NV
    2
    Quote Originally Posted by chem geek View Post
    Thanks for the advice. I'll get on this. Any suggestions instead of triclor?
    38,354
    Yes, read the links I provided, specifically the last.
    And post up the test results.
