Thread: GFCI Plug on Pump
    Aug 2014
    Baton Rouge
    7
    GFCI Plug on Pump
    If I have a GFCI plug on my pump, does it need to plugged into a GFCI outlet?
    Jun 2013
    Indiana
    57
    Re: GFCI Plug on Pump
    No, but if the outlet is close to the pool it should be GFCI protected so that anything else plugged in will not be a risk.
    IG plaster, 22,000 gallon, Jacuzzi Laser Sand filter
