Thread: Hot tub draining back to pool
    Aug 2014
    pasadena tx
    4
    Arrow Hot tub draining back to pool
    We had a big lightening strike at the heater area. Has not worked since. Looks like an error code PR 6. Does not click anymore when I try to turn it on. I think its the board. Any ideas?
    Aug 2014
    pasadena tx
    4
    I REPLACED THE CHECK VALVE BUT IT STILL LEAKS BY WHEN THE PUMP IS OFF. I CAN CLOSE A MANUAL VALVE AND STOP IT BUT WHEN PUMP COMES BACK ON THEN MY SPRAYERS COME ON TILL i GO OPEN THE VALVE. I ONLY PUT A NEW FLAPPER NOT THE WHOLE VALVE BODY.
    38,516
    Re: Hot tub draining back to pool
    WHY ARE YOU YELLING AT ME!?!?!
    Welcome to TFP!!!
    If you can close a valve and stop the draining, then it seems like you have isolated the problem. The check valve or a 3-way valve must still be leaking.
    boston62's Avatar
    Jun 2014
    Fort Myers, Florida
    461
    Was the correct flapper installed to the right body of the check valve? I had this happened to me Jandy flapper on Compool check valve body...won't work.
    13,000 Gal Pool & Spa
    Jandy Automation /w IAqualink
    Autopilot SWG
    Jandy 2.0 HP VSP, Filter Cartridge
    Taylor (FAS-DPD K-2600, Pool Surface: Plaster
    Aug 2014
    pasadena tx
    4
    Great thought, its a Jandy valve body and not sure about the new flapper. Will check that out. Thanks
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Welcome to the forum Tommy
    Can you please add your info to your signature as outlined here - > http://www.troublefreepool.com/conte...etting-started
    Solar Blanket, Well Water, Borax Added. 76
