Results 1 to 8 of 8
Thread: suggested timer
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    suggested timer
    Ok guys I'm tired of running out to turn the filter on and off. What is a reliable timer I should get and where can I get it?
    2nd ques, pump running at night or during the day?
    40x18 Lazy L Rectangle
    29500gal IG w/ vinyl liner
    HAYWARD S244T 300lb sand filter
    Hayward Super Pump 1 1/2hp
    38,251
    Re: suggested timer
    1. Intermatic T104 (assuming your pump is 230V, T101 if it is 115V). They are bulletproof. Make sure to get the outdoor enclosure if it will be exposed to weather. Google them
    2. Does not really matter. Run when power is cheaper or whenever is convenient, knowing that the pump should be on for 30-60 minutes before you test and after you add chemicals. Often good to run in a few short periods throughout the day.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: suggested timer
    My pump says 115/230. Guess it can go either way. Hayward superpump 1 1/2hp
    38,251
    Re: suggested timer
    Check the breaker or measure the voltage.
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: suggested timer
    Its on a double 15amp breaker
    38,251
    Re: suggested timer
    Well, there you go, must be 230V, so the T104 is what you want ... either the T104P (plastic) or the T104R (metal).
    TrevNJPool's Avatar
    Jul 2014
    atco/nj
    142
    Re: suggested timer
    Thanks alot.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: suggested timer
    I put a T104R on mine 3-4 weeks ago. Check around on prices. I got mine from zoro.com for $45 shipped. Lowes wants nearly $70, and some pool supply places want over $100.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
