Thread: New Pool balancing chemicals
    I've been doing TFP for a few years with our previous pool, but somehow I still second guess myself. I'd just like a fresh set of eyes to check that I'm doing things right.
    We just moved and built new pool, which was filled 11 days ago. I know there will be fluctuations for a while due to new plaster curing so for now, I will post my last two results (with TF-100).
    Yesterday 8:30am
    CC - 0
    FC - 2 (added 160 oz of 8.2% bleach)
    Ph - 7.2 (I've been adding MA for the last week to keep it between 7.2 & 7.5 and it seems like it finally stopped creeping up).
    TA - 100 (also has been dropping slowly with the balancing of Ph, it was 130 last week)
    CH - 110 (added 5lb of hardness plus yesterday, in three increments in a span of 2 hours)
    Today's results stayed the same (chlorine is not holding up) but CH did go up to 170.
    Questions:
    -Normal that chlorine is dropping this much?
    -Do I keep raising the CH until I reach 250? Or do I focus on lowering TA?
    Thank you!!
    Built in 2014, 18,000gal, plaster, in ground, Pentair Clean & Clear Plus 2.0 HP, Booster Pump, Cartridge filters, inline chlorinator, automatic cleaner, Pentair MasterTemp 400 heater, Silencer for SPA.
    Bloody hot summers in Katy, TX; the rest of the year is just plain hot!
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,187
    Re: New Pool balancing chemicals
    Quote Originally Posted by mvoorn View Post
    Questions:
    Have you added CYA/Stabilizer? With a fresh fill and none added the sun is going to burn off the FC in a few hours
    Support the site
    Aug 2010
    Dallas, TX
    4,052
    Yes, 2ppm FC will drop to zero quickly, especially if CYA is 0. Of course if CYA is 40, 2ppm FC is too low anyway.
    Yes, shoot for 250 on CH for now, it may creep up on its own for a few weeks with new plaster. Don't lower pH to 7.2 or likely your CSI is going to go too low with CH of 250 or lower. Use PoolMath, fill it all in, and report back what it says for CSI at 7.2. I had this same problem with my pool after replastering.
    38,371
    I think you want to ignore the CH and TA for a little while with new plaster as they will rise as the plaster cures, although bumping the CH up to around 200ppm should be safe.
    As Tim said, you chlorine problem is because you do not appear to have added stabilizer. You should add at least 30ppm and eventually target 50ppm due to your location.
    How are you adding chlorine?
    Are you actually using the inline chlorinator listed in your signature?
    I forgot, the PB did add stabilizer, my CYA test on Sunday marked 40.
    I'm adding just plain old Walmart liquid bleach: NOOOoOooo to the puck inline chlorination (I should edit that to say 'not in use')!
    I'm trying to keep my FC target to 5 (in track with the 40 cya).
    Oct 2013
    Chapin, SC
    1,141
    It's not unusual to drop 2-3ppm FC daily even with an adequate CYA level.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
