Results 1 to 12 of 12
Thread: Mustard Algae or Pollen
    FC 7.5
    CC0
    PH 7.5
    TA 70
    CH50
    CYA 70
    All season I've had yellow stuff in the pool. Slammed back in July cleared up the cloudiness. The yellow stuff started building up again. I think it's pollen; we had a bad season of pollen this year. The stuff is on the bottom running on the seams of the vinyl liner other places mostly in the shallow end. My pool gets full sun. Brushed and put the robot in last night. I did an over night FC and measured the same as last night no contaminates! I didn't see the yellow stuff today yet. Can I assume that it's pollen?? Does mustard algae register in the overnight FC as a contaminate?
    Any suggestions on getting rid of it? I wonder if I put stockings in the skimmer baskets to see if it would catch it all?
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Re: Mustard Algae or Pollen
    Mustard Algae may not register CCs... I've seen in it my pool when I was battling Mustard Algae... When you brush does the cloud go green? If so, it's definitely algae and not pollen IMHO.
    We did have a bad pollen season, but it appears to be over a while ago.
    I hope for your sake it's not mustard algae because it's a BEAR to battle against.
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    Thanks for the reply. I will have to check and see if it goes green. I thought I was in the clear when my overnight CC's remained the same.
    Central, VA
    I have a SWG and the pump was turned off last night when I tested and this morning. My pool is clear no CC's and posted the overnight test. What should I do?
    Central, VA
    mas985's Avatar
    Pleasanton, CA
    11,742
    Mustard algae is usually on the shady sides of the pool. Pollen usually falls to the bottom. Do you see a lot pollen on the deck and/or nearby cars?
    Mark
    It's all located on the bottom of the pool on the lines of the vinyl never had it on the sides or floating been there all summer off and on. No pollen on the deck or cars. Could it just continue to come back if it's pollen? I only backwash every couple weeks because I use my robot not the vacuum and the PSI's are stable.
    Central, VA
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    Hate to say it bust it sounds like mustard algae... you should SLAM your pool and brush as often as you can. I can tell you that it took me two weeks of SLAMMING at MUSTARD LEVEL to get it to go away.
    I hope it doesn't work out for you that way.
    Did you remove your light if you have one? Don't think we can do that because of it's location. But all of the algae is on the bottom.
    I was afraid that's what I have to do..
    Anyone else have any input?
    Central, VA
    mas985's Avatar
    Pleasanton, CA
    11,742
    I am not sure it is Mustard Algae. You have a sand filter and that can let small particles through. Some pollen is smaller than what a sand filter can filter out so what I would try is adding some DE to your filter (~1 PSI rise) and then manually vacuum up all the pollen. See if it then disappears. If it comes back, then I would suspect live algae of some sort. But again, all of the mustard algae outbreaks that I have read about on this forum have been on the pool walls and not the floor.
    Mark
    Thank you I will try this first. Where do you buy DE? I've read how to use.
    Central, VA
    mas985's Avatar
    Pleasanton, CA
    11,742
    All pool stores will carry it but also Home Depot and Lowes carries it too. Maybe even Walmart.
    Mark
    Thank you
    Central, VA
