Results 1 to 7 of 7
Thread: Is this normal for inground liner?
    Aug 2014
    trenton nj
    2
    I recently had a new liner put in. After filling the pool up I noticed the liner was pulling away from all the corners of my grecian shaped pool. This looks like great place for a tear to happen. I usnderstand the liner needs to stretch a little but this seems like a little too much for me.
    I've been given conflicting assessments. The installer says it's fine, my buddy who installs liners says that the liner was cut too small, which is evident by the floor seam not reaching one side of the pool. The seam should be tucked into the corner, but it is not, it is a good 4 inches off on one side. The other side is fine.
    Please take a look at the video:
    http://youtu.be/st9nZrTSEBc
    Any insight is appreciated!
    DD
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: Is this normal for inground liner?
    Contact the installer, have him come on and inspect and get it in writing.
    Aug 2014
    trenton nj
    2
    The first day that the pool was filled I asked them about it. I also had a corner coming away from the coping at the top. They fixed that and said the rest was normal. It's already in writing in an email.
    Oct 2011
    Minnesota
    164
    I have 6" radius corners in my in-ground pool, and the liner has a hard time in each of the corners. My liner is like yours and was also installed that way 3 years ago.
    20x44 IG vinyl. Intelliflo, Pentair Cartridge Filter (420ft^2), Raypac 336K, Kreepy Krauly
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,465
    Was your old liner like that?
    I do know if that is normal or not as I have an AG round pool and the liner is snug every where-sides, bottom, where sides meet bottom.
    I would NOT like it and would ask to see other pools with your kind of liner to see how they fit.
    Looks like it is ripe for messing up. I would worry about the liner on the bottom the most. You KNOW someone will step there and it will cause a problem IMO.
    Good luck!
    Kim
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    There is always some gap, but that is a bit extreme. Mine is about an inch is all and no where near that. They did not measure correctly at all and you should ask them to fix it properly.
    I would call another pool company and get a second opinion in writing. Then send that information all to the installer and demand it to be redone. If not, then file a civil suit on them to have it fixed or demand your money back so that you can go somewhere else to get it properly fixed.
    I need a liner in another year myself and the pool installer I have is good. I have seen what they have done to other people in town and when they screwed up, they totally remeasured and re-installed it properly to make it right. The one I have now was installed by the previous homeowners who did not even take care of it. My liner is weak and I may get another year on it but at least I have a good installer lined up when I decide to have it replaced in another 2 years is my plan.
    Good luck!
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Mines looks just like that on the shallow end. I don't remember if the deep end is like that or not. I just bought my house with the pool. The pool is six years old. My biggest gripe is the bleaching of the liner from the stupid granular shock the previous owner used to open and close the pool. They also rusted my ladder with it. I guess they just sprinkled it on everything.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
