Results 1 to 16 of 16
Thread: Help with cloudy water
    Aug 2014
    Raleigh, North Carolina
    9
    Cool Help with cloudy water
    Sand was changed in filter 2 wks ago and still cloudy water is coming out of the return jets - the #'s are :
    FC - .12 (1-4ppm), TC 1.4 (1-4ppm), CC 1.28 (<0.2ppm), pH 7.6 (7.2-7.6), TA 117 (80-120ppm), Calcium 200 (200-500ppm), CYA 39 (20-50ppm) .... brackets are ranges. The pump had an issue of not priming correctly, so had no filter usage for 10 days, but when it was restarted, tested, shocked, tested, and got all levels back up, but now the cloudy jet returns have started a week ago. Never had this problem before. Recirculate does clean water, so thinking it's a filter issue, pool store, pool owner don't know what to do except keep running filter 24/7.
    4000 Gal IG Vinyl, NO SWG, Sand Dollar, Pentair Super Flo, screened enclosure over pool.
    38,284
    Re: Help with cloudy water
    Welcome to TFP!!!
    How are you testing?
    Please review the ABCs of Water Chemistry to get us on the same page.
    Also take a look at what levels we recommend: http://www.troublefreepool.com/conte...mmended-levels It is important to understand the FC/CYA relationship shown in the FC/CYA Chart.
    How are you saying that the pool clears on Recirculate? No water goes through the filter in that mode.
    Aug 2014
    9
    Hey Jason ..... I spent a lot of time last night reading the ABC's and have seen where my FC is very low and the CC is very high, which could mean some form of Algae is eating the FC ..... I strip tested (I know you don't like this, but all I have at moment) this morning, filter still running, and FC still way low, CC high .... dumped in a gal of bleach, will test soon .... I'm thinking from ABC's that bleach needs to be added til FC and CC is norm ..... please correct me or more help. Thanks in advance. I'm on my way to become a TFP Supporter, and get the test kit savings .... TFP appeared and pool store disappeared !
    38,284
    Good choice on the TF-100 ... it ships out of Raleigh, so you should have it tomorrow
    Once you have the test kit, you will need to follow the ShockLevelAndMAINTAIN Process to get the pool cleared up. Once we get the chemistry fixed up, then we can make sure the filter is working.
    Post up a set of test results when you get the kit. Note there are youtube videos of all the tests linked to from tftestkits.net and there is also more detailed instructions here: Extended Test Instructions
    Aug 2014
    9
    Thanks Jason ..... looking so forward to this pool problems/relationship and the kit .... since it ships out of Raleigh, can I go and pick it up to save ship charges ?
    38,284
    I am not sure. You could call and ask.
    Aug 2014
    9
    Hey Jason .... this is what I did today - tested this morning before putting in bleach, results were all over the place .... then dumped in a gal of bleach, and this was at 11, waited til I got more bleach, took a test at 2 ish, FC and TC still wacky, so added another gal bleach at 3, and now just tested - mind you, I'm still using strips til kit gets here ..... and these strips don't have a CC - FC - 3
    TC - 3
    pH - 7.6
    TA - 130
    CYA - 40 the sun is off the pool now (usually get 6 - 8 hrs sun) so I didn't add anymore bleach now, will check later this evening and in morning, definetly seeing a difference with the jet returns not so much cloudy , and water is clearing up, but I'm not gonna stop treating ..... tomorrow I plan on backwash, rinse and go from there .... Big thanks for ur help and the info on this site, ya saved me !
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Until you get the test kit and start a proper SLAM more than a gallon or two of bleach a day is really being wasted. I know you want to be doing something to fix the problem, but be patient.
    Support the site
    Aug 2014
    9
    Here it is Wed and pump is having issues again, an air leak that needs to have housing replaced, so I ordered housing and a K-2006 TEST KIT COMP CHLORINE FAS-DPD also, housing will be here Thurs and kit sometime next week ..... the test wasn't accurate this morning due to pump issues, but the water sure is clear as can be .... will update after pump gets restarted Thurs evening or Fri .... Thanks.
    Aug 2014
    9
    OK, Fri morning, at 8:00 and pool tests are perfect numbers .... all of them .... please, don't even ask, I'm not listing them.... I'll keep checking back every so often for more info, but Thanks for the help and have a Good whatever ....
    May 2013
    Fort Lauderdale, FL
    423
    Attitude?
    45'x12' 17k gal, IG plaster, Pool Pilot Nano+ SWG, 1/2hp Whisperflo pump, PAC-FAB TA-60D sand filter, Raypak 266 heater
    Pool School + Test Kit + Pool Math = Trouble Free Pool
    Aug 2014
    9
    Yeah, ya might call it Attitude, cause of some previous comments that have since been deleted. Otherwise I'm fine.
    May 2013
    Fort Lauderdale, FL
    423
    Well regardless, glad we could help.
    Aug 2014
    9
    Update - got new housing installed, and test kit arrived and checked the numbers and everything is in order, so decided since I'm good, I'll check back if anything arises that I would need help with. Thanks again.
    May 2013
    Cyprus
    159
    WOW
    That is some gaff, looks really relaxing. Nice one
    Living in Cyprus
    Still enjoying life
    Aug 2014
    9
    Thanks
