Results 1 to 9 of 9
Thread: Algae
    Apr 2014
    Upper Chichester, Pa
    60
    Algae
    At the end of my rope with this pool for 4-5 weeks of this now. I have kept this pool at slam shock level and its fine but as soon as it drops to level of 10 algae begins to grow back. Now I have slammed this pool for 2 weeks now begin to let the levels drop and this morning here are my results and I can see algae forming again. Any advice??? Why is this happening? I literally have not used this pool in weeks because it just keeps growing back as soon as I let the levels drop below slam level. Initially I was thinking it was the filter so I have someone coming today to check the filter out but I would think if its filtering at the right the PSI its working? Any advice why it keeps growing back below slam levels for this long?
    FC 13.5
    CC 0
    TA 100
    CYA 50
    PH 7.8
    Sharkline Reprieve 21' x 52" Round Above Ground Swimming Pool, Waterway 520-5220-6S ClearWater 19in. Sand Filter Above Ground Pool System with Hi-Flo Single Speed Pump, using BBB method and TF-100 kit
    Apr 2014
    60
    Re: Algae
    2 nights ago crystal clear
    This morning Algae forming
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,668
    Re: Algae
    Your levels look good as I am sure you know.
    My ideas:
    -steps and lights-have you taken them out and scrubbed them?
    -Filter-have you opened it up and looked at the sand? Have you done a deep clean? Here is a link
    http://www.troublefreepool.com/threa...-a-Sand-Filter
    Other than that all I have for you is a hug.
    Kim
    Apr 2014
    60
    Re: Algae
    Yes I have done all that. I have taken those steps out several times weekly, vac daily, cleaned that filter I just don't know.
    Thanks for the hug
    Can we swim with a level of 20? LOL
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    Re: Algae
    Hi tammy,
    You can swim with FC all the way up to shock level. No prob.
    There has got to still be some algae somewhere. Think of everything you can.
    Behind the light
    in the autofill
    in a waterfall pipe that hasnt been used
    in any other pipe that hasnt been used
    It's there somewhere. It has to be.
    Divin Dave,
    Apr 2014
    60
    Re: Algae
    I don't know where, I don't have lighting, waterfalls, I have cleaned every inch of that filter pipes, behind the ladder, we pulled the whole ladder out of the pool scrubbed it with bleach, scrubbed every part of the vac and supplies. I scrubbed every inch of inside and bottom of the pool with bleach, slammed it for 5 weeks and sure enough it drops below slam level and here comes the algae.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Re: Algae
    I will ponder a guess. For AGP the main cause is skimmer box and weir, and also steps and ladders. The ladder fills with water and just sits. My problem in the past was the anti-entrapment behind the ladder. After about a week I could see yellow through the hole in the top. I got a funnel and some tubing. I pour a few oz of bleach in every few weeks.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: Algae
    My hidden source was also INSIDE of the ladder. The outside was constantly scrubbed and remained algae free. I pulled the ladder out and covered all of the tiny little holes with duct tape. Then I funneled in bleach /water solution in the bigger holes and let it sit for about an hour. When I turned the ladder upside down to drain it, that when the neon green came pouring out. Just a thought.
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    Apr 2014
    60
    Re: Algae
    hmmmmm thanks I will try this today
