Thread: Polaris Hose will NOT stay on
    Jul 2008
    Suwanee, GA
    The hose on our Polaris will not stay connected where the hose attaches to the cleaner with the screw on compression fitting.
    I have tightened the fitting as tight as I can but it comes off again a couple of minutes.
    Any tricks or suggestions?
    Free Form In-Ground with Pebbletec
    ~15,000 Gallons
    Goldline SWG
    Polaris 280
    ? Pump
    ? Heater
    Cartridge Filter
    Re: Polaris Hose will NOT stay on
    Check to make sure that you are using a pressure restrictor. The red or blue plastic disk that fits in where the Polaris plugs in to the wall of the pool.
    "Whatever happened to the guy who drained his whole pool?"
    27,000 gal plaster in-ground
    Compupool 40k SWG from eBay - works great!
    Polaris 380
    Hayward DE
    1.4 HP Hayward Northstar pump
    Two FAFCO Solar Bear panels now heating the pool!
    Richardson, TX
    I have found that sometimes I need to just trim off about an inch of the plastic hose, it seems after a couple of years it gets weaker, at least on mine (360, so it's running all the time unless I go 1/2 speed or put the fountain in). I think my next option will be getting a new 'joint' fo rthe thing...that seems to be squirting out a little more than before...
    My pool works thanks to TFP
    Please support the site! pages/supporters/
    It's cheaper than your first trip to the pool store!
    Jul 2008
    The nut should be placed on the fitting first, then the hose is attached, and the nut is then screwed up onto the hose.
    It can seem like the nut should be placed on the hose first then the hose pushed onto the fitting and then the nut is screwed down to compress the hose, but that is the wrong way.
