Results 1 to 10 of 10
Thread: Pool cubby help
    Aug 2014
    Sackville
    10
    Pool cubby help
    Newbie to the pool seen. I have a pool cubby with a sc-36 salt cell. When I run the "pool pilot test" what should the voltage and amps reading be in "boost" mode?
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Pool cubby help
    Voltage will vary but good voltage will typically be in the high teens/possibly low twenties with 5.0 amps. If there is an issue the amps will typically be affected first.
    Josh Ulfers - josh@saltpoolguys.com - 888-725-8766
    SaltPoolGuys.com - AutoPilot Pool Pilot Systems, Parts & Cells - AquaCal Heat Pumps
    Aug 2014
    Sackville
    10
    Re: Pool cubby help
    When I unplug the controller and plug it back it runs 17v 5a.
    When I come back in an hour and test again it says 2v 5 amp. Still in boost mode is this normal?
    Jul 2014
    Hope Mills, NC
    567
    Re: Pool cubby help
    Amps are what break up the salt molecules, 5 seems right according to my SWG. My volts change a lot, too.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Aug 2014
    Sackville
    10
    Re: Pool cubby help
    Ok thank you very much!
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Pool cubby help
    Quote Originally Posted by Dixon View Post
    The 17 volt / 5 amp reading is perfect. However if the unit is dropping to 2 volts while in boost that could be a concern. Do you notice the voltage "jumping around" much? I would run several tests over a few hours and see what readings you get.
    Aug 2014
    Sackville
    10
    Re: Pool cubby help
    After the first hour it always seems to be around 5 volts 5 amps.
    The cell is new. What should I check next?
    Aug 2014
    Sackville
    10
    Re: Pool cubby help
    Anyone?
    JoshU's Avatar
    New Orleans, LA
    542
    Re: Pool cubby help
    Have the readings been sitting at 5 volts/5 amps with the unit sitting at 100% and/or "boost" mode? Are you sure it isn't reading 15 volts?
    Aug 2014
    Sackville
    10
    Re: Pool cubby help
    It's at 2 volts 5 amps after an hour and stays that way
    At 100 percent
