Thread: a few bugs present, but CC comes back as 0
    Jul 2013
    Cedar Rapids, IA
    82
    So, I have a few waterbugs, mostly the ones that look like skinny roaches and skate across the surface, plus one boatman.
    FC: 8
    CC: 0
    Ph: 8.2
    TA: 90-100
    CYA: 50-60
    Ph was high today so I added 30 oz muriatic to bring that down; before today it had consistently ran around 7.8. Also added some bleach to stay on the high end of my normal range.
    CC is consistently 0, only rarely does it come back as 0.5, but I've been reading around here that bugs may indicate algae.
    I had about a dozen of the skaters and 1 of the boatmen, netted most of them out yesterday then gave them the underside of my shoe, today saw a couple and did the same.
    So, question is, should I be concerned about the presence of algae, considering the reading of 0 for CC yet also given the presence of a few bugs, or should I just keep on keeping on?
    Edit: I'm using TF-100 for my test results
    24,300 gallons, IG vinyl, Hayward Pro Series S244T sand filter, 3ft to 9ft deep
    38,524
    Re: a few bugs present, but CC comes back as 0
    I am not sure why this rumor seems to be so prevalent ...
    Having algae does not necessitate the presence of CCs ... and having CCs does not necessitate the presence of algae.
    How does your water look? You could do an OCLT to verify there is not some hidden algae outbreak.
    I have noticed a few bugs in my pool as well, I am not sure where they come from, but I do not think they necessarily mean there is algae in the water.
    Jul 2013
    Cedar Rapids, IA
    82
    I may have made some incorrect assumptions. I was going off of the rule that CC of 0 to 0.5 generally means your water is clean, while 1 or above indicates a problem. I read a few threads that seemed to suggest waterbugs could also indicate problems, and thought the two conflicted.
    Maybe I read a bit too much into it.
    Water is sparkling clear.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    CC alone doesnt mean there is an actual problem. It is a indicator that there is a possible problem that needs further testing.
    If your OCLT is good, clear water and less than .5 CC then you are good.
    FWIW,
    I KNOW my water is good, and I get a few bugs on mine too. Now if you had 1000 bugs, that might be an idicator for more thurough investigation.
    Divin Dave,
    Jul 2013
    Cedar Rapids, IA
    82
    Quote Originally Posted by Divin Dave View Post
    FWIW,
    Makes sense, hadn't thought of doing the OCLT, I'll try that out.
    Thanks for the responses.
