Thread: salt water system numbers off from taylor salt water test
    Aug 2013
    Mcallen, TX
    39
    I noticed that my salt levels have not decreased in over a year according to the salt water system. There is a discrepensy of 400 between the taylor test and my actually cell. 3000 for the taylor and 3400 for the salt cell, is this pretty normal to get something like this? Also, whenver i add salt to my pool is there a way to reset my salt water generator to get the new results or should it automatically gather that information?
    17k gallon pool, pentair whisperflo pump 1hp, Pentair FNS Plus 36, SWG Hayward Turbo Cell 15 40,000g, blue quartz with pebble finish landings/bench, ultra pure water cleaner.
    Aug 2010
    Dallas, TX
    4,052
    Re: salt water system numbers off from taylor salt water test
    I have found it is quite common for my test results and the cell's results to be off. I trust the drops, but I want to make sure the cell is happy.
    Can't answer your question on the new results item. Mine automatically retests every hour or something like that.
    38,235
    Mine is always 400ppm off ... except my test is higher than the SWG reading.
    You should have the SWG off for 24 hours after you add any salt. The salt level it reports is just based on the conductivity of the water, so when you add salt, the conductivity will go up. There is an instant salt reading and an average ... eventually the average will come up.
    Oct 2013
    Chapin, SC
    1,141
    The instant is what the swg uses to determine whether or will generate or not. The average only changes very slowly. My circupool runs on a 200 min cycle, so I believe the instant is reset at the beginning of each cycle.
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
