Results 1 to 10 of 10
Thread: FC Testing Q
    Tom Tank's Avatar
    Aug 2014
    Fuquay Varina, NC
    31
    FC Testing Q
    New pool owner and recent convert to the TFP method. Using the TF100 test, my CYA=100, so I know I need to drain water, but really don't want to do that until the season is over. So I am left with maintaining a pretty high FC between 7-12. My questions are: Because my FC level needs to be higher than 5, do I have to use the FAS/DPD daily? Is there a way to dilute the water and use less of the drops or use the OTO test for chlorine that is higher than 5. Thanks.
    22,200 gal, IG Vinyl 3.5' - 8.5', Haywood s240 Sand Filter, Polaris 180
    manually chlorinate, 2 skimmers - 1 main drain - 3 returns plus waterfall feature
    TF-100 test kit, pool in sun ~10am - 5pm
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: FC Testing Q
    Just use the FAS-DPD. I've been on TFPC for 3 years and I've never done an OTO test. When you're wrestling with a CYA that high, you really need accuracy and precision in that upper range.
    Tom Tank's Avatar
    Aug 2014
    Fuquay Varina, NC
    31
    Re: FC Testing Q
    Is there a way to dilute the water for testing for FC? I am in the middle of a SLAM and have to maintain a FC=39.
    Aug 2010
    Dallas, TX
    4,052
    Re: FC Testing Q
    You'd have to use distilled water, tap water will have FC in it.
    Are you sure you are at 100? Have you tested CYA with a 50/50 tap/pool water mix?
    Tom Tank's Avatar
    Aug 2014
    Fuquay Varina, NC
    31
    Re: FC Testing Q
    I have tested CYA with the 50/50 mix and it was a little under 100. For FC testing, what would the calculation be if I used 50/50 mix in the 10ml tube? Is it 1:1?
    38,275
    Re: FC Testing Q
    Until you need the accuracy to know you are done (for the CC test and OCLT), you can just use 5ml of water where each drop is 1ppm.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: FC Testing Q
    Quote Originally Posted by Tom Tank View Post
    If I understood that correctly, your CYA reads slightly under "100" with a 50% dilution, it means your CYA is actually ~200ppm (or more).
    Tom Tank's Avatar
    Aug 2014
    Fuquay Varina, NC
    31
    Re: FC Testing Q
    Sorry if I wasn't clear enough, CYA was slightly under 50 so I doubled it to 100 since I was using a 50/50 mix. Is that the correct?
    May 2014
    584
    Re: FC Testing Q
    Yes, that is correct.
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Re: FC Testing Q
    Sorry... deleted post
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
