Thread: Solar Heater Panel - Chewed up by Critters
    Jul 2008
    Reno, NV
    13
    So, I finally got my solar panels assembled with hard plumbing, no leaks.
    Been running it the last several days just fine.
    Started it up this morning, just fine.
    It's this kind of solar heater.
    Went out a couple hours later and some kind of critter managed to poke/chew holes in several of the channels on the bottom.
    That is seriously very frustrating.
    One of the reasons I had to hard plumb the pool was something was chewing holes in the flex pipes.
    We've got all kinds of critters here I guess. Chukar, Quail, Hawks, Squirrels, Rats, Mice, Rattlesnakes, Coyotes, Jack Rabbits, CottonTails.
    Hard to figure out who did it, but they look more like punctures/pecks than rodent chewing.
    Has anyone else ever had this happen? Any suggestions for fixing besides the 'plug it with a machine screw' method?
    Thanks!
    Brent
    Splash Around 20' Round Above Ground Pool, 1hp Pump Motor, Cartridge Filter (9,000 gallon)
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    Re: Solar Heater Panel - Chewed up by Critters
    My first recommendation is to get a bunch of live traps to help remove these "critters" from your yard.
    I live in ND so you can about imagine the kind of things we have out here. Skunks are a common thing here.
    I am sure the professionals will chime in soon with suggestions on how to fix those leaks so pay close attention as they really know what they are doing.
    Good luck!
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Glad the hard plumbing is working out for you! As for the solar panels, I would suggest getting them up off the ground a couple of feet so whatever is biting them can't get at 'em. Maybe even plan a night where you can stay up and watch to see what comes by and does damage.
    Now, about fixing the holes in the panels, machine screws are one option. Another option I read about somewhere is to heat the plastic around the hole, then push it together until it seals. For bigger holes you could heat the plastic around the hole then melt another piece of plastic to fill the hole. If you search on this forum with something like "hole in solar heater" you can probably find the thread.
    HTH,
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
