Thread: Sand in pool at start up
    Hello all,
    I replaced my filter with a Hayward S244T top mount sand filter, the bearings went out on the Hayward Super Pump for the third time so I replaced the pump with a Pentair 1hp "direct replacement pump" The Pentair seems to be a much better pump and the motor is beefier than the Smith motor on the hayward pump.
    I purchased the sand from a locally owned pool store and specifically asked for the No. 20 sand.
    Everything went well for a few weeks but now when the pump is turned on I get about a pound of sand (its being caught in a mesh bag so I know its sand) through the return.
    I have the top off the filter and am draining it for a look-see, any advice on what to do next?
    20 x 40 Vinyl, w/ Pentair 1 hp pump & Hayward 24" top mount filter
    Re: Sand in pool at start up
    I found the issue, a lateral came loose, now to empty the sand and put it back together.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Great job figuring it out.
    Aug 2010
    Dallas, TX
    4,052
    Shop vac to the rescue!
    Boy, that would be a huge job for me! (600 lbs of sand)
    After removing the sand and the laterals I found that when the assembly was put together at the factory they stripped out one of the screws. I shot a photo of the stripped out screw and will see if Hayward will warranty it.
