Results 1 to 7 of 7
Thread: Cloudy water
    May 2014
    Banning Ca
    3
    Cloudy water
    I think I have mustard algae!
    I was gone for a couple days and came home to no clorine and a brown yellow tint at the bottom and lower sides of my pool. Added 2 lbs of shock ultra blue algicide, brushed, vaccuumed, back flushed filter, repeated. Now it's not sticking to the bottom but the water is cloudy and slightly brownish yellow. I do not have the option of replacing water , due to severe drought and monitored meter from the city. ( they are fining for over use).
    Here are my test results from the TF-50
    FC 13
    CC 0.5
    TC 13.5
    CH 250
    TA 160
    CYA 90
    Not sure what to do
    Should I add DE to catch the fine particles that seem to be coming back through the filter?
    I'm new and have had this pool since may this year.
    Thank you for your help
    15,000 AG embassy 16" sand filter 1 HP built 5/25/14. I'm new and lost :)
    38,547
    Re: Cloudy water
    Welcome to TFP!!!
    Your CYA is pretty high, so a 50% water replacement would be ideal. To clear up the pool, you need to follow the ShockLevelAndMAINTAIN Process, which would be easier at a lower CYA level, but not required. Your FC is no where near high enough for this process. See the FC/CYA Chart.
    What is your pH? You may need to order FAS-DPD refills or you may run out prior to clearing up the pool. You are looking at using over 60 drops for each FC test.
    May 2014
    Banning Ca
    3
    Re: Cloudy water
    Ph is 7.8 and yes I will need to order replacements for that and also the CYA agent. I can't replace my water so if there is a long road to take to get the results I need I am willing to take it. I think I figured out how much clorine I need to add to get the pool to shock level . I just put the goal amount in the calculator along with the current reading and it said I needed to add 200 oz. so I'm off to get that . I appologize for the lack of understanding how this all works but I am learning and it will get easier I'm sure
    38,547
    Re: Cloudy water
    Your shock level is 35ppm, you are currently at 13ppm ... according to PoolMath for a 15k pool you need 498 oz of 8.25% bleach. I am not sure how you got only 200oz.
    Plus remember that you need to maintain the FC at 35ppm until you pass the 3 criteria to stop ... so you will need a lot of bleach.
    And remember ideally you should lower the pH, but the test is not valid when the FC > 10ppm.
    Aug 2010
    Dallas, TX
    4,052
    Re: Cloudy water
    Don't add any more powdered shock, most of them add CYA.
    You are close enough to Los Angeles that you might be able to find a company that will do reverse osmosis on your water.
    May 2014
    Banning Ca
    3
    Re: Cloudy water
    Sorry for the typo it was 400 oz 10% bleach. I added and brushed pool again. I also bought DE I was thinking of adding that to my filter to help with the tiny particles would that be recommended ? Looking into the reverse osmosis but it seems pretty expensive for my budget right now. It's been an hour and the pool looks better.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,216
    Re: Cloudy water
    A one or two time addition of "shock" is not going to fix the problem, but following the SLAM Process will.
    Support the site
