Thread: Re: Optimal flow rates for variable speed pumps
    May 2014
    La quinta
    3
    Please do not add your question in another poster's thread. It creates confusion and your question does not get the attention it deserves by being lost in another thread. Butterfly
    I would like to run my VS at 1500 rpm. I have the main and skimmer plumbed seperate .? Should I shut off main drain to get a better flow rate to the skimmer or maybe lower water level to 1/3 wier door hieght and the try 75/25 skimmer to main ratio?
    Apr 2013
    Sacramento, CA
    2,769
    What problem are you trying to solve?
    You want a low rate on your pump but are concerned the skimmer won't clear the pool? Do you have lots of trees? Do you also run a pool sweep?
    I'd just lower the pump speed and see what happens for a week. If the debris clear then you don't have a problem. Its always good to have a deep suction source for better circulation and filtering.
