Results 1 to 20 of 20
Thread: Lowering TA to Add Borates
    Jul 2014
    St. Simons Island, GA
    172
    I'm sold on the idea of adding borates. Step #1 is to lower TA. I started today at 140 TA. Brought pH down to 7.0 with muriatic acid. Now to aerate to raise pH via aeration. Given my rather nifty aeration, how long should I anticipate this will take to raise pH back up to 7.5?
    Home pool: Intex 11,400 gallon AG vinyl pool with sand filter & SWG. Taylor K-2006 test kit - coastal Georgia. I'm also in charge of the Elk's Lodge Pool, which is 55,000 gallons in-ground concrete with sand filter, 2 HP Hayward pump, currently using tri-chlor pucks and cal-hypo system.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Lowering TA to Add Borates
    Difficult to say and anyone giving you a number would be guessing. Your fill TA is fairly high, so it may take a little while. If you are following the TFPC guide for this, then you know you have to get that TA down before adding.
    Essential Links:
    Jul 2014
    172
    Change of aeration device! The other one seemed ineffective. (I'm using a koi pond pump, not the pool's pump to do this.)
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Days or weeks. Mine will bounce the pH quickly back up to 7.2...like three or four days, then struggle to pull it past that. I got my TA down by lowering to 7.0 each time I hit 7.2, stepping the TA down a bit each time.
    I'm doing the exact same thing as you right now, for the same reason. Your aerator may be a bit better than mine.
    Fayetteville, NY -17K gal, IG vinyl, Hayward SP2300VSP Max-Flo Variable Speed Pump, FlowVis Flow Meter, Sand filter
    Self designed Arduino powered automation for pump and solar control, Solar Attic Pool Heater, AutoPilot Digital SWG, TF100
    Jul 2014
    172
    Surprise, surprise. pH was up to 7.8 when I got home. Added a 2nd aeration device using a 1/3 hp sump pump(see pic) and more muriatic acid to bring pH down again. This may not take all week!
    Butterfly's Avatar
    South Carolina
    10,045
    You're done SLAMing when:
    Aug 2010
    Dallas, TX
    4,052
    I love your tenacity!
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    What is your TA now?
    wjr75's Avatar
    Jun 2013
    IL
    836
    It took me three months and a new plaster finish which used 6 gallons of muriatic acid to go from a TA of 130 to 70. I have a slide which runs water into the pool and a hot tub which we use the jets occasionally. When we close the pool in a month and a half I plan on adding boric acid to the hot tub which we keep open until December.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2014
    172
    Quote Originally Posted by peterdaly View Post
    100-110. Not sure which b/c I went from 8 drops to 11. (Yes, I can be impatient.)
    Also, I just added another 4 cups of muriatic acid b/c pH was already back up to 7.4. Will let it circulate for a while b4 I measure pH again.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by wjr75 View Post
    It took longer because the new plaster was putting out calcium hydroxide and/or had plaster dust (calcium carbonate) both of which increase pH and TA. You only get the TA down much faster when the primary source of pH rise is from carbon dioxide outgassing. If one has a lot of evaporation and refill with water high in TA, then that also makes lowering the TA take longer.
    peterdaly's Avatar
    Aug 2013
    Fayetteville, NY
    188
    Chem geek - I just went from 110 to 70 with 4 steps down with muriatic acid. Am I correct in my gut feel that it's harder to increase the pH through aeration as the TA level goes down?
    Results of my aeration on pH seem slower, but I don't know if that is due to other factors.
    Mar 2007
    San Rafael, CA USA
    12,082
    Yes, you are correct that as the TA gets lower it takes longer for the pH to rise. That's really the point because you want to have a lower TA to have more pH stability when using hypochlorite sources of chlorine. This table shows you how over-carbonated water is compared to the carbon dioxide in air. Notice how lower pH and higher TA is more over-carbonated. That's why you lower the pH for the procedure to accelerate the outgassing (the aeration also accelerates this and is part of the process) and that the water becomes less over-carbonated as the TA gets lower.
    There is a direct fixed relationship between the amount of acid added and the reduction in TA so you can accurately estimate your TA drop based on how much acid you add during the process. For your 17,000 gallon pool, it takes 43-1/2 fluid ounces of full-strength Muriatic Acid (31.45% Hydrochloric Acid) to lower the TA by 10 ppm.
    Jul 2014
    172
    This morning pH was 7.8 and it required 56 oz. muriatic acid to bring it down to 7.0. The first dose was 48 oz. TA test pink-ish (kind of not really) at 10 drops. Red at 11. So TA did not significantly change overnight.
    Butterfly, what does mean?
    Mar 2007
    San Rafael, CA USA
    12,082
    Are you sure that you don't have static electricity making the titrating drops in the TA test too small or squirting out? Wipe the dropper tip with a damp cloth. 56 ounces of full-strength Muriatic Acid in 12,500 gallons should lower the TA by 17.5 ppm so should have been measurable.
    Jul 2014
    172
    I am amazed .... or incompetent. Test results when I got home from work: pH 7.8, TA 80, FC 10 (ran SWG last night and again today semi by accident kind of not really). So, I poured a very small, unmeasured bit (maybe half a cup?) of M.A. in, let it circulate with aerators still on, and then disassembled aerators without performing any further tests.
    Going to give the pool a rest tonight.
    Oh, ChemGeek, the 56 oz of M.A. was added this morning. Last night was only 4 cups, or 32 oz.
    Hmmm, almost out of CYA reagent. Getting low on FC reagent as well. That didn't take long!
    Oct 2013
    Chapin, SC
    1,141
    I took out my aerators last fall --didn't need any more pH. And neither do you right now! My SWG manual says pH should be between 7.2 and 7.8
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Jul 2013
    Gilbert, Az
    116
    Quote Originally Posted by timerguy View Post
    hes trying to lower his TA quickly to add borates
    12k - free form - plaster- Nautilus fns48 DE filter- centurion 1hp (so quiet)- In floor cleaning system with Jandy Caretaker - TF-50 and 5 in 1 test kit, Phoenix, Az
    May 2014
    Mesa, Arizona
    180
    From experience, I feel that you are doing the right thing by getting the TA of your pool to 70 ppm. Pool Math works very efficiently and is very accurate. Getting my TA down to 70 before the addition of boric acid was very crucial indeed. I did the addition in halves, added half of the boric acid; then half the muriatic acid. Finished it off with what the pool math configured and bam, my PH was exactly where I started and the TA was minimally higher (seriously, just a tick higher).
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
  20. Back To Top    #20
    Jul 2014
    172
    Well, I got busy (and lazy) plus I used the last bit of my R 0871 for the FC test and last bit of R0013 for CYA test on a friend's nasty, neglected pool. So, I'm in a holding pattern of doing a whole lot of nothing until new supply of reagents arrives.
    I'm going to start a new thread regarding the friend's pool.
