Thread: Wish me luck...
    mark-o's Avatar
    Jun 2014
    Bossier Louisiana
    18
    Wish me luck...
    3rd liner in 2 months due to bad seams. Between the water and chemical cost I need a second, maybe third job.LOL. Excuse the pic my pool really isn't sideways.20140805_195123.jpg
    16 x 36 inground vinyl w/ covered steps. 9 1/2 ft deep end w/ diving board. 27,000 gal.
    PacFab Challenger 1 1/2 hp 2 speed pump, Pureflo 300 lb sand filter, Pentair chlorine feeder
    1 skimmer, 1 main drain, 3 return lines and NO LEAKS "knock on wood" LOL.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: Wish me luck...
    Good luck! Good lookin' liner you have there.
    Divin Dave,
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Re: Wish me luck...
    Luck at you!
    At least you have a few weeks left on the season - I'm astonished to being seeing closing threads already!
    mark-o's Avatar
    Jun 2014
    Bossier Louisiana
    18
    Re: Wish me luck...
    We will probably have about 4 to 6 week left. I never really shut it down. I have a T-stat that kicks my pump on below 40 degrees so I keep it full and running all winter. We don't really have what you would call a real winter down here.
