Thread: Universal Wall Mount for Polaris 380 Pool Vac
    The quick connector hose for the pool keep shooting out of the universal wall mount. I can't get the Polaris hose connector to tighten up to the wall mount (keeps spinning). The wall mount has the two stubs within it, so they're not broken off. The Polaris hose connector seems to look fine. Thought I would try swapping out the Polaris connector and if needed, the Universal Wall Mount. I've tried to remove the wall mount to inspect it, but it won't budge even with large channel locks. I'm hoping a new connector is all that is needed. However, if the mount also needs to be replaced, how do I get that thing off the wall? Not much room to grab it and unscrew it. Any and all thoughts re: a solution to my situation is appreciated.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Universal Wall Mount for Polaris 380 Pool Vac
    Bump
