Thread: Controlling overflow?
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    I am in the process of building a small 12z24 on a small patio. Should I including any overflow system? What do you recommend? It rains a lot here in Miami! How common is it for people to use an overflow control, and how often do pools overflow?
    Aug 2010
    Dallas, TX
    4,052
    Re: Controlling overflow?
    When mine overflows, it just goes into the yard, and has never caused me any trouble.
    38,271
    I would think an overflow would be a good idea for you in FL ... not really a problem here, I need an auto-fill
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Yup. that water has to go somewhere. Depending on your yard and the capacity of it to hold or drain water, then just a PVC pipe into a drywell will do. If thats a problem it may be necessary to run a overflow pipe to your sewer or to a street drain. Some places actually have building codes about doing that though.
    If your filter will be of backwash type, you can set it to backwash and pump out the water when it gets too high.
    Or you install a vacuum to waste vavle between the pump and filter and just direct excess water out of the pool that way.
    Quote Originally Posted by ssml11 View Post
    Divin Dave,
