Results 1 to 14 of 14
Thread: 2 Speed vs Variable Pump for small pool?
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    I am building a small 10k gallon 12x24 rectangular pool and I am debating whether to go for a 2 speed or a variable speed pump.
    Some factors I am considering between the two are cost, energy consumption, reliability, etc.
    I read I could run a 2 speedy in low 24/7...would that be overkill on my electric bill? I already read variable pumps require lots of surge protectors and stuff.
    I've been debating this back and forth...what do you recommend for my build? Any pumps in mind you'd care to mention? How much HP?
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    Re: 2 Speed vs Variable Pump for small pool?
    Electricity in my area is 12.2 cents per kilowatt hour (kWh
    38,251
    Your power is pretty cheap, the 2-speed makes more sense financially and are more forgiving of nearby lightning strikes. Get a 1HP 2-speed like the Superflo and a timer. Running on low 24/7 is still overkill. See this article in Pool School: http://www.troublefreepool.com/conte...-pump-run-time
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I would only consider a variable speed if I had waterfalls, fountains, solar panels, or the like. Otherwise a 2 speed gives the same benefit as VS for much less $$.
    There is no need to run on low for 24 hours.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    What schedule do you recommend to run a 1hp 2 speed? Also, I see pumps like superflo 2 speed for for around $550 vs a variable counterpart can go for maybe $200 more. I really don't see much $$ there...but for the sake of simplicity if a 2 speed will still save me electricity then I think I will go for it.
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    And no, I have no water fountains. I will be adding four deck jets on the deck...and I am considering getting a cheapo 1hp 1 speed just to run those when the kids are playing in the pool.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I run my two-speed 95% of the time on low. Once it's primed on high, I check the filter pressure I switch to low. I've got a basic T101 timer and a high/low toggle switch I mounted on the motor. The only time I'm on high speed is prime the pump after I clean the prefilter or to check the pressure, other than that I'm on low. I replaced my single speed 3/4 hp with a two-speed 3/4hp.
    Here's how I have set it up: http://www.troublefreepool.com/threa...P-2-Speed-115V
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    Quote Originally Posted by bobodaclown View Post
    Interesting setup...I would love to duplicate that. That way I don't have to manually babysit and switch to low speed.
    Aug 2010
    Dallas, TX
    4,052
    Quote Originally Posted by svenpup View Post
    Unless you have a pool the size of mine! 24 hours on low is cheaper than 8 hours on high, and seems just right to keep the pool clean. That said, I have considered backing it off a little, but not until it cools off.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I do something similar to bobodaclown but with more automation. I have a TightWatt2 Timer that I have configured to run 15 minutes on high and then drop down to low for 10 hours. If you prefer Intermatic timers, they make the P1352ME which is similar to the TightWatt2.
    Quote Originally Posted by RobbieH View Post
    OP says 10k gallon 12x24.
    Aug 2010
    Dallas, TX
    4,052
    I know, I just wanted to make sure everyone understood that was not a blanket statement, some of us do have to run 24/7.
    38,251
    The Superflo 1HP 2-speed can be found for under $450. BTW, it comes with union fittings for easier plumbing and has a switch on the motor.
    I used to manually control mine. I would make sure it was primed on high and then leave it on low speed on the timer. I left it like that for months in the winter. Then in the summer when I wanted solar heat, I would leave the pump on high speed. Now the automation automatically switches speeds for solar when needed.
    Apr 2011
    Murrieta, CA
    2,360
    Oh living in lighting capital of the US (Florida) with relatively cheap electric a two-speed is the way to go.
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    Thanks for the Feedback. I am now just opening a new Thread now with the actual drawing from the engineer with what they recommend. Fee free to check it out under the title "Finally here's the Diagram - Thoughts? -Pump Selection?
