Thread: Another Happy Stenner Customer - acid dilution vs run-time
    Jul 2011
    Austin, TX
    61
    Using the recommendations from this forum, I added a stenner acid doser to keep the pH down. After some quick calculations and testing, I was able to dial in the stenner in the first attempt. The pH hasn't budged in a week (although I still can't help myself from checking it everyday)!
    I do have a quick question - what is the trade off between acid concentration and run time? I have a 5 gallon container that I currently have a 1:1.5 acid to water ratio stored. My mind tells me that 1:3 dilution would be better for the parts, but of course, it would make the pump run longer.
    Any recommendations? Should I be concerned about running the pump for 4 hours per day. BTW - the stenner is the fixed flow 3GPD pump.
    16,000g in-ground plaster pool, attached spa, BBB, DE Filter, SWG
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Another Happy Stenner Customer - acid dilution vs run-time
    The dilution rate does not matter to the Stenner. All of the chemical being pumped is trapped in the tubing and never comes in contact with any of the internal pump parts.
    They are also rated for continuous duty, so they can run 24/7 without damage.
    Support the site
