Results 1 to 14 of 14
Thread: Should I drain some water?
    Jul 2011
    Bath Pa
    29
    Hi all, I have a salt water pool
    Cya level is 95
    Ph 7.2
    FC 6.5
    Cc 0
    Ta 50
    Do I need to drain pool like pool math says ? Says I should drain 16%
    Robin
    central new jersey
    24x12x52 intex ultraframe swg 1650 sf
    Jul 2011
    Bath Pa
    29
    Re: MA effects on TA; Can CYA drop/evaporate?
    Hello , now I'm seeing white particles in the water with the high cya any thoughts on what I should do ?
    Robin
    central new jersey
    Jul 2011
    Bath Pa
    29
    cya high
    hello cya is too high . pool math is telling me to empty 16% of my pool . here are my readings
    fc 6.5
    cc 0
    tc 6.5
    ta 50 added baking soda as told by pool math
    cya 95
    Robin
    central new jersey
    Oct 2013
    Chapin, SC
    1,141
    Re: Should I drain some water?
    The white particles are probably a result of your swg reversing polarity to self clean itself. Probably not much to worry about. Though I was a little myself when I started seeing them after I installed mine. But they disappeared quickly and haven't been seen since. You might want to do the drain and refill to get your cya down to 70-80 range
    Pool size: 24000gal inground Vinyl-Taylor k-2006 and k-1766 test kits and-speed stir
    Intermatic P1353ME digital timer w/freeze sensor
    CircuPool Si-45 SWCG System
    Polaris 280 vacuum/Polaris PB4-60 boost pump
    Pentair IntelliFlo VS 3hp Pump--Pentair sand filter
    Aug 2010
    Dallas, TX
    4,052
    TA is a little low. What is your CH? Although CH doesn't matter in an above ground pool, it does if it gets too high. White particles are usually from high CH.
    Aug 2010
    Dallas, TX
    4,052
    Re: cya high
    Hey Robin,
    It will help if you keep your posts together in just one location.
    38,426
    Merged all the threads. Please keep related questions together to not clutter the forum. Thanks, jblizzle
    May 2014
    Mesa, Arizona
    180
    I was wondering why he kept saying hello...a full battery of tests would help us help you more.
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
    Jul 2011
    Bath Pa
    29
    cya 95 sw do i need to drain
    hello I thought I posted this but I cant find it
    super technically challenged
    fc 6.5
    cc 0
    tc 6.5 added baking soda
    ta 50
    cya 95
    pool calculator says drain 16% just checking to se if I have to
    thanks in advance.
    ( don't know how to type either )lol
    Robin
    central new jersey
    Jul 2011
    Bath Pa
    29
    thanks all . I still don't know if I should be alarmed and empty the 16% or not from the post. I didn't just fill it but cya was only 20 so I added and must have put in to much . so I guess my question is with a cya of 95 is it necessary to drain.
    also ive got fc but no other chlorine is that dangerous ?I don't want a green pool as to fill it is costly
    thanks
    i also added baking soda to bring up ta. sorry i never use a computer as i do not know how to type so im technically challenged.
    Robin
    central new jersey
    38,426
    I would suggest you check out ABCs of Water Chemistry because based on your question about chlorine, you have not fully grasped the chemistry. Also review Water Balance for SWGs.
    If your water is clear and the SWG is maintaining adequate FC, then the CYA is fine. If you need to SLAM, then you might consider lowering the CYA.
    Jul 2011
    Bath Pa
    29
    Re: cya high
    im sorry i really didn't know i hadn't kept them in one place. i try never to use this as i i don't know how and once i learn i forget anyways . i do not trust my pool store at all and buy all my supplies from tfp
    Robin
    central new jersey
    Jul 2011
    Bath Pa
    29
    sorry i was told the pool math is the bible so im scared and yes i have read it and it seems conflicting and confusing. i guess im just not good with chemistry and technology
    Robin
    central new jersey
    38,426
    Continue to ask questions and eventually you will understand.
