Thread: Safe Chlorine level
    Jul 2014
    Houston/Texas
    7
    Safe Chlorine level
    I am having a pool party for a bunch of junior high kids. Would it be wise to raise my chlorine level BEFORE the party and if so how high can I take it and still be safe to swim? Or is it best to just wait until after the party.
    I have a SWCG so I would be adding bleach.
    Mike
    33,000 gallon IG pebble, SWG - Aqua Rite w/ Hayward T Cell 15, DE filter - Pentair FNSP 60, single speed pump, pool age 13 yr, spa, test kit TF100, Polaris 280
    38,298
    Re: Safe Chlorine level
    That sounds like a very good idea to bump it before. It is safe to swim up to the shock level for you CYA see the FC/CYA Chart. But, you do not need to raise it that high. Just add 4-5ppm is probably good and you likely want to bump it up again after.
    Aug 2010
    Dallas, TX
    4,052
    Since I'm guessing you have your CYA in the right spot around 70-80, don't be afraid to take it up to 9PPM, that should be more than enough. I did the same thing recently, evne though it was a huge party of adults. We probably had 30-40 people in the pool at one point.
    May 2014
    Mesa, Arizona
    180
    Quote Originally Posted by RobbieH View Post
    Now that's a pool party! Each person had more than 1,000 gallons to swim in!
    IG Pebbletec Blue Tahoe; Paddock Pool PCC 2000 pop-up; 22,275 gal 32' x 16' Diving with Auto-Fill
    Pentair 420 Cartridge filter; 3 hp VS Whisperflo Main Drain, 1 1/2 hp Whisperflo Running Pop-Ups; Jandy AquaPure 1400
    1 1/2 Whisperflo dedicated to Rock Waterfall; TF-100; Taylor K-1766; Pool Built in 1997
