Results 1 to 8 of 8
Thread: Pool cover pump to drain water from pool too?
    Jul 2014
    Cleveland, OH
    9
    Hi guys,
    This seems like a question that is hard to find a direct answer too. Either because it is obvious or not good to do at all.
    Can a pool cover pump also be used to drain a pool as well? This pool I got with my house didn't have a drain setup on the pump/filter and because of the distance from house/pool I don't really want to tackle that right now. I just want to mainly drain a couple inches off the pool when it fills with rain above the skimmer (we been getting a ton) and to also use to half drain the pool to close for winter. I can run a hose to a drain though. I am not concerned how long it would take but more if those pumps are made for that long of pumping and would burn out. I don't really want to spend $300+ on a gas pump that I will use only a few times a year. I was just thinking one of those ~$150 pool cover ones.
    Thanks
    Oct 2013
    Iowa
    82
    Re: Pool cover pump to drain water from pool too?
    Although I can't find any duty cycle specifications or anything like that for our cover pump, after 2 years (with us, not sure how old it actually is) of living in the elements and pumping nearly all of the rain/snow/ice from the cover it does seem quite durable. However if I needed to pump from the pool a few times a year and didn't have a main drain I would probably go buy a cheap utility or sump pump from a local hardware/DIY store instead of using a ~$150 cover pump. It doesn't sound like you need the automatic plug it in and forget it, freeze protection, pump to less than 1/8", etc features that the more expensive cover pump has.
    20,000gal in-ground 16x36 sentry pools vinyl liner, Pentair sand filter, Pentair minimax NT heater, auto-cover, Polaris 280 cleaner.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    I used my cover pump over the winter to pump out about two feet of precip. No problems. It certainly won't overheat! But a utility pump is cheaper if you don't already have the cover pump.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Just a basic sump pump works for me. http://www.homedepot.com/p/Superior-...i_src=17588969
    With either a garden hose of for faster pumping a larger diameter sump pump hose. http://www.homedepot.com/s/sump+pump+hose?NCNI-5
    Solar Blanket, Well Water, Borax Added. 76
    Jul 2014
    Cleveland, OH
    9
    Awesome, thanks for the advice everyone!
    Jul 2014
    Hudson Ohio
    142
    Does your pump / filter not have a waste setting on the valve? I turn mine to waste and let the pool pump drain it down.
    24'x54" AGP 13,500g AquaLeader Sentinelle | Hayward Voyager CC150 sqft cartridge filter | Hayward 2hp 2spd pump | Hayward Aquaray Cleaner
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,683
    Where are my manners . . Welcome to the forum
    When you get a chance can you please add you pools info to your signature as outlined here http://www.troublefreepool.com/conte...etting-started
    Jun 2007
    New Jersey
    653
    Anthony & Sylvan had to do an acid start-up on my new plaster pool after the free Nature2 system cartridge ruptured and metal stained the brand new pool (Nature2 now long gone). They put a Little Giant cover pump (theirs, not mine) on top of the drain cover to circulate the acidified water. It ran for a week 24/7 and that was it's normal job.
    More recently, I did the same thing with my Rule pump when my original pump motor fried. It ran 24/7 for about ten days. Brushing to circulate is for the birds--apologies to all who suggest it.
    So I'd say they can take it.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
