Thread: New member / New pool owner
    Good morning everyone.
    I am a new pool/spa owner, and happened across this forum while researching how to operate the pump and heater on our new pool/spa (just bought the house, never owned one before).
    Here is my issue:
    The spa is built onto the pool (sits just a tad higher), and flows water into the pool with pumps running.
    We want to use the spa heater, but dont know how to go about changing all the valves around to have the heater/pump running in the spa-only without having to run the pool as well.
    I have included pics of the equipment, with the valves set normally (pumps running both pool and spa)....hopefully one of you can help me through the steps (im sure i would burn something up trying to troubleshoot it myself..).
    Thanks in advance for all your help.
    http://s96.photobucket.com/user/ddog...ry/Pool%20Pics
    Aug 2010
    Dallas, TX
    4,052
    Re: New member / New pool owner
    Welcome to TFP!
    I have no experience with spas, but I'm sure someone will be along that can help.
    Thanks...hopefully you're right.
