Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: 12x24x52 install progress pictures
    Aug 2014
    oxford/GA
    23
    Hello. I just want to share my pictures from our DIY install of our Intex Ultraframe 12x24x52 rectangle pool. My mother and I completed most of this work ourselves. My husband helped some but his job keeps him away from home most of the time. We had to dig in to get level ground. We shored up the sides with stakes and pt lumber. We packed in granite sand by raking, wetting, tamping and screeding. We used a transit to shoot the top of the box and then I built a jig to screed. We buried pt 2x12x15 and shot grade using the transit on each of the 18 leg supports. ]I think it's turned out great so far. Next will be our deck.
    http://s1376.photobucket.com/user/tr...Install?sort=2
    Aug 2014
    oxford/GA
    23
    Re: 12x24x52 install progress pictures
    Not sure how to upload more photos. I get a message that says I've exceeded my limit and I've only 3 photos.
    38,235
    To post more pictures, you either need to raise your storage allotment by Becoming a TFP Supporter or follow the How To Post Pictures tutorial.
    Just a note, many members (myself included) do not typically click on links to albums. I prefer to see the pictures directly in the thread. You just have to paste the IMG link directly into the post.
    Aug 2014
    oxford/GA
    23
    Thanks for the help. Hopefully this works.
    Apr 2013
    Battle Creek, MI
    298
    Quote Originally Posted by trailbuddy69 View Post
    http://www.troublefreepool.com/threa...oto-s-Tutorial
    18'x4' AG Intex Ultra Frame, 6,700 gal., assembled new 2013; Mods: Hayward EC50C90 Perflex filter & 1 h.p. PowerFlo Matrix pump, Fiber Clear cellulose D.E. substitute, Hayward H100ID1 100,000 BTU NG heater, a pair of 2'x20' Sungrabber solar heaters via the original Intex 635T pump, grey Hydro Tools through-the-wall skimmer, Confer steps/ladder system & Cover Free chemical pool cover. The Summer of Mods!
    Oct 2013
    Los Angeles, CA
    87
    Nice set up how how sand did you put down and how is it holding up?
    Intex 12 by 24, Intex 2600 sand filter (soon to upgrade), deck under construction
    jmcdtucson's Avatar
    Jun 2014
    317
    Any time I see surveying equipment and obviously professional set up screed boards, I can only say "nice job".
    Intex 12'x24'x52"
    8,403 gallons
    Intex SF60110 2450 GPH Sand Filter
    Intex CS8110 SWG
    Aquabot AJET121I Pool Rover S20-40
    Aug 2014
    oxford/GA
    23
    Quote Originally Posted by jmcdtucson View Post
    We put in 6 tons of granite sand. I am a 45 year old female accountant and my mother is a 63 year old retired bartender. She and I borrowed a relatives transit to shoot grade and we cut and installed all of the retaining boards ourselves. We had the sand delivered but we shoveled by hand and raked and hand tamped and wet and tamped some more. I built that screed board myself out of scrap lumber from another project. She and I worked and pulled that sand around by ourselves. I'm very proud of the "nice job" we did. I think we did a much better job than alot of so-called professionals. Just because we aren't professionally trained to do this kind of work doesn't mean we can't do a professional job.
    jmcdtucson's Avatar
    Jun 2014
    317
    Absolutely! Looks fantastic.
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Aug 2014
    oxford/GA
    23
    Here are some photos of our entry deck we built over the weekend. Yes, we did it ourselves. My husband was home this time to help. It is 5x8 and made of pressure treated lumber. I bought some tiered cake steps from a friends so now we just walk right into the pool. More deck will be added over the winter and I plan on adding a set of steps from the upper deck to the pool level deck.
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    Looks great!! Good Job? Do you want to do one in Texas?
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    Aug 2014
    oxford/GA
    23
    Quote Originally Posted by florentino View Post
    We had a good bit of rain a few days ago and some of the granite sand washed out from under the lowest point. I went back with some pieces of roll roofing cut to size and dug out the sand, nailed the roofing material to the board and folded it down to the ground and then put the sand back on top. The sand is only a couple of inches deep at the most and it seems to perk thru rather than run off. We are definately keeping an eye on it since we were dealing with such unlevel ground and we had to dig down almost a foot at one end and side. I'm considering smooth river rock down on the sand base just to stabilize things.
    jmcdtucson's Avatar
    Jun 2014
    317
    You are inspiring me. Maybe I'll build a deck sooner than later. Thanks for the pix!
    Intex 12'x24'x52"
    8,403 gallons
    Intex CS8110 SWG
    Jun 2014
    Toronto, ON, Canada
    98
    Looks great! Wanted to get this exact pool next year.
    12' Intex Metal Frame Pool, 1500 gallons, Intex 2800gph Sand filter/pump, AquaPro PRO1100 HP, K-2006 Test Kit
    Apr 2014
    FOUR cORNERS
    111
    got kids or grandkids?? that upstairs porch looks temping to jump off of, just saying!!!!!
    16 'x 48" Metal Frame Intex 5065 gallons, 14 Inch sand filter,Hayward Skimmer SP1091LX Dynaskim, Test Kit TF-100
    Aug 2014
    oxford/GA
    23
    Quote Originally Posted by POPPA S View Post
    My kids are grown and live in others states. But....many years ago when they were in elementary school, we had an above ground 24' round. I came home from work to find they had moved the trampoline to the area between the house and pool. They had put up a ladder against the house and were jumping from the roof to the trampoline and then bouncing into the pool. I thought I'd have heart failure!
    Jun 2012
    Northest Florida
    23
    Nice work! now at some point do you back fill around the pool ?
    MrsDimples's Avatar
    Jun 2014
    England
    47
    That looks great.
    Hope you & your Mother are proud of your work.
    Intex 10ft Metal Frame - 1,185 gallons
    Intex 530 gall. per hour Filter Pump (Model No. 58604) - Cartridge
    Chlorine / pH dip sticks
    Intex 3kw Heater
    Aug 2014
    oxford/GA
    23
    Quote Originally Posted by offthefront View Post
    We will not back fill against the pool. I am planning to build somewhat of a boardwalk that will extend/cantilever over the hole where the pool sits and then set potted plants as a deterent from stepping off into the abiss.
    Quote Originally Posted by MrsDimples View Post
    That looks great.
    We are. It's been a lot of hard work with more to come. I sure hope it's worth it and we get many years of enjoyment from it. I don't know how long to expect the Intex pool to last. A friend of ours just took down their Splash pool because they moved. It'd been up for 15 years.
  20. Back To Top    #20
    Aug 2014
    oxford/GA
    23
    More pictures of our install. The flimsy little skimmer basket that came with our Intex just wasn't working for us. I bought a Hayward wide mouth skimmer and, with a little ingenuity, created the Frankenstien you see here. I was able to connect to the existing Intex hoses and it seems to be working well.
    12x24x52 Rectangle Intex Ultra Frame AGP with 1,600 gal. per hour Krystal clear sand filter and saltwater system combo pump.
