Results 1 to 8 of 8
Thread: "Magic TCCA" Tablets - Anyone Used these?
    Hi,
    I use Sodium Hypochlorite as my main source of Chlorine but once in a while use TCCA 90% Tablets to maintain the Cyanuric Acid level.
    My Pool Chem supplier is now offering what they call "Magic TCCA" tablets which are a mix of TCCA, Alum and Copper Sulphate. The specs are:
    Available Chlorine - 83%
    Aluminium Sulphate - 4%
    Copper Sulphate - 2.5%
    PH Value - 2.72
    Has anyone used these? Is there any downside to using these over the regular TCCA 90% Tablets? I do maintain 50ppm borates using Borax.
    Thanks.
    14000 Gal. Inground Overflow Pool with DIY Sheer Waterfall Return. Norman Robotic Pool Cleaner.
    TechnoPool PH Acid Doser. DIY Chlorine Doser. Waterco 2.5HP Pump/Filter with Glass Media (0.8mm Glass Beads).
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: "Magic TCCA" Tablets - Anyone Used these?
    Using products that add copper is a bad idea.
    Quote Originally Posted by PAGirl View Post
    Hi, what would be the bad / good effects of using copper?
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    It can cause staining, can turn the water green, and also will discolor blonde hair.
    Thanks.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    The copper is there to act as an algaecide. If you keep your FC in range you won't need to worry about algae. If you decide you need an algacide to prevent algae (algacides don't kill algae very well) use a polyquate 60 based algacide. Stay away from anything that adds metals to the pool.
    Love TFP? Become a
    TFP Supporter!
    Mar 2007
    San Rafael, CA USA
    12,082
    The aluminum sulphate is an "alum floc" that is used to clarify the water, but that is also not necessary if you maintain proper chlorine levels (FC/CYA ratio) and have adequate circulation/filtration.
    As for copper staining, it is a particularly hard stain to remove (compared to iron staining or calcium carbonate scale) and will happen when the copper level rises and/or the pH rises (when copper is present). You most definitely want to avoid adding copper to your pool.
    Thank you all. I have ordered the regular TCCA 90% Tabs.
