Thread: IntelliCholr and EasyTouch RS485 communication
    yzf600's Avatar
    Apr 2013
    Phoenix, AZ
    24
    I'm looking for someone who has an IntelliChlor IC40 hooked up to an automation controller. If you have this setup, have you ever hooked up an RS485 sniffer to record the conversation between the SWG and the controller? If so, would you mind sending me some recorded data? I would be your friend forever
    I recently bought a IC40 for my pool (15k gal.). With my pump runtime and the IC40 @ 20%, I still get too much chlorine in the pool. I guess I should have chosen the IC20 instead, but I was swayed by the argument that spending a little more on the IC40 would be worth the extended cell life. I saw the posts about the default 20% increments being too coarse in my situation, but I valued longer cell lifespan. Hindsight is always 20/20 (or 20/10 as the case may be). I could just go buy a timer and set it, but that solution seems like taking the easy way out.
    I recently built my own controller out of a wireless micro-controller. I already have it talking to my pool pump to turn it off and on. I would like to be able to control the SWG in 1% increments as well, but I need some RS485 example packets to decode the communication. Probably what I need is to a recording of the bus while you use the EasyTouch to change the percentage of salt generation. Also a recording of turning the SWG on and off would be nice. I'm also curious to see if the EasyTouch transmits the percentage command to the IntelliChlor occasionally as well. I suspect this is required if the power ever goes out and the IntelliChlor resets its default SWG percentage.
    Worst case scenario if I can't decode the protocol is to just switch the return water to the waterfall, bypassing the SWG as needed. Or I could just use a spare relay on my home grown controller to power cycle the SWG. I'm up for the challenge of decoding the communication, though.
    15k gallon, salt water, plaster, Pentair IntelliFlo pump, Hayward 48 sq ft DE filter, Pentair Intellichlor, hayward Aquanat 200 pool vac ultra located in Phoenix, AZ
    Mar 2007
    Murrieta, CA
    215
    Re: IntelliCholr and EasyTouch RS485 communication
    Interesting topic. I just googled for the protocol, and I found the following info that might be of interest to you.
    http://cocoontech.com/forums/topic/1...-2#entry203939
    It doesn't have the answer that you're specifically looking for, but it might provide some insight to the command protocol that Pentair uses.
    ~13500 gallon gunite pool, Pentair Intelliflo 4x160, Pentair 520 SF cartridge filter, Pentair MasterTemp 400 NG heater
    Pentair Easytouch with IC40 SWCG, Hayward Navigator on dedicated suction line
    Jun 2016
    San Jose, CA
    1
    Quote Originally Posted by peterl1365 View Post
    I got something pretty substantial up and running. GitHub - tagyoureit/nodejs-Pentair: An application to read/write to Pentair pool controllers.
    Dec 2016
    Austin, TX
    115
    Quote Originally Posted by tagyoureit View Post
    Does your code require an easy-touch to be installed or can it replace the need for an easy-touch?
    Dec 2016
    Austin, TX
    115
    I just read through some old stuff I found. Here is another link I have looked at.
    pavsp_rs485_examples/rs485_master at master · eriedl/pavsp_rs485_examples · GitHub
    I have a software friend that is helping me with my project. We are just looking at existing code and planning so far. The plan for me is to have two VSP's, a heater, many valves, swg, etc... all controlled using an RPI. No Pentair controller.
    Tagyoureit's code so far looked the most promising as a start. Since I am not the best at software (learning as I need to), please excuse any dumb questions.
