Thread: Testing the strength of liquid bleach
    Quote Originally Posted by JasonLion View Post
    Welcome to FTP!
    {EDIT}Corrected an error in the procedure as originally written.{/EDIT}
    There is a way to test the strength of bleach, but it isn't really all that simple. You need to dilute the bleach by 10,000 to 1 and then test the diluted bleach. One way to do the dilution is to add 10 ml of bleach to 1 liter of water, mix throughly, then add 10 ml of that to another liter of water, mix throughly and then test the FC level. The two liters of water need to be chlorine free, commonly distilled water is used. Also, the 10 ml measurement needs to be as accurate as possible, typically done using a syringe or pipette.
    I did just that Jason and I got 10 ppm on my 2006 test kit. Is that possible? For bleach that high? I used distilled water and a 10 ml dropper Thank You Dave G.
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Re: Commercial bleach: testing concentration
    If you followed the procedure, that reading indicates you have 10% bleach.
    and that's what I got Abigail, that amazes me the bleach was that strong
    Im amazed and hope its right
    38,275
    Re: Testing the strength of liquid bleach
    What bleach did you test? Many stores sell 10% and 12.5% liquid chlorine.
    If you tested the 8.25% bleach, then it must be pretty fresh.
    Personally I see no need to test new bleach since there is no need to try to be exact in your dosages.
    The bleach I bought was at Home Depot which again I wouldn't think it would be renewed as regularly as Walmart, but Im sold!
